Old 02-09-2019, 01:59 PM   #1
Tom
Seachaser186's Avatar
Home RV Power Outlet Box
Finally getting around to installing a 30 Amp power box at home. Well, the design of the box does not allow the lid to close with my current power cord.
Just wondering what the best option is and any advice or opinions would be appreciated. Click image for larger version
ID:	196420Click image for larger version
Seachaser186 is offline   Reply With Quote
Old 02-09-2019, 02:10 PM   #2
007matman's Avatar
Why is it mounted on a flat horizontal surface? Couldn't you mount it on a wall?
I would think it wouldn't be an issue that way..
007matman is offline   Reply With Quote
Old 02-09-2019, 02:11 PM   #3
I have the same issue with my post mounted power box. Old power cord wasn't an issue as it didn't have the big handle.
My plan is to merely fabricate a cord for home use that is only long enough to reach from my power post to the power inlet. A 90 degree connector for the trailer end and a low profile plug for the box end. Since I park the trailer in pretty much exactly the same position I'll make the cord short enough that it doesn't hang low enough to touch the ground. With the outlet and inlet less than 2' apart I certainly don't need a 25' cord lying on the ground.
Will make it easier for me to mow/weed whack in that spot. I can then leave the regular cord in storage while "docked" at home.
On the OP's box, it might be possible to add a strip of sheet metal to the edge of the cover on three sides, using pop rivets and sealer, as well as a new hinge on top. Essentially move the cover out enough to allow it to close over the high profile cord plug.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
Old 02-09-2019, 02:17 PM   #4
Kanadian Kamper
kenandterry's Avatar
There are deeper utility boxes available.
Measure twice or three times......then buy.
Ken and Terry
2018 Sunseeker 2430S with Trekker cap
and only rarely pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is offline   Reply With Quote
Old 02-09-2019, 02:23 PM   #5
When mounted to a pole the lid/cover is going to keep it 95% dry. Why worry about it. Most campgrounds I go to the lid wont close all the way with my cord plugged in.
Kimber45 is offline   Reply With Quote
Old 02-09-2019, 02:41 PM   #6
007matman's Avatar
That's where I'm coming from.
I think it would be fine if it was mounted on a pole or on the side of the house.
Old 02-09-2019, 03:24 PM   #7
Tom
Funny! I have not installed it yet; it is laying flat on the swim platform of my boat. Anyway I have some ideas, just don't want to cut the handle off the plug. May buy a new cord for home use with no handle or modify a 30 Amp dog bone.
Old 02-09-2019, 03:31 PM   #8
dbledan's Avatar
You can get a dog bone adaptor that would fit but it adds another connection.
dbledan is offline   Reply With Quote
Old 02-09-2019, 03:32 PM   #9
007matman's Avatar
I think you're going to be fine using it as is of you're mounting it to a wall. What little moisture makes it on past the open sides is going to be below the plug.
It's your comfort level though . It it makes you sleep better at night do what you think is best.
Most of the time when we're camping the boxes are that open and it's never hurt a thing.
Old 02-09-2019, 03:35 PM   #10
I'm gonna make believe I didn't just read that!
Old 02-09-2019, 03:36 PM   #11
Just wondering what the best option is and any advice or opinions would be appreciated. Attachment 196420Attachment 196421
As long as it's not plug in during a Hurricane I wouldn't worry about.
Old 02-09-2019, 03:39 PM   #12
I think it looks rather nice on the boat dive platform.
Old 02-09-2019, 03:50 PM   #13
007matman's Avatar
Yeah.. you can so see that it's not mounted in the photo.
Yes, I can be sarcastic too..
Old 02-09-2019, 03:52 PM   #14
I installed the very same box from Lowes, and if doing it again, I would buy one with the breaker in the box, ... my power panel is in the garage only about 15ft away, and I thought "why spend the extra money, that close, it won't be a problem", ... it's not a big problem, but is inconvenient to have to go into the garage and open the power panel every time I want to kill the power, ... it would just be more convenient to have the breaker there in the outside box, and I may exchange it some day, but for now I just live with it, ...
fella10 is offline   Reply With Quote
Old 02-09-2019, 03:54 PM   #15
I ordered mine from home depot.com came prewired with a 30 amp and 20 amp breaker and has the 30 amp plug and a 20 amp plug about 50$
Old 02-09-2019, 04:28 PM   #16
Citrus County, Fl.
GL1800Rider's Avatar
Mine is just a gang box with a flip lid mounted on a 4 x 4 post. I have a 2 x 12 over the top to keep the rain out. Has worked for 19 years including a tornado and few near miss hurricanes.
I agree it would be more convenient having a breaker on the box. Probably would have saved a couple of miles walking over the years
Name:	30-ampRV pedestal recepticle.jpg
ID:	196436   Click image for larger version
Name:	RV box cover.jpg
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 02-09-2019, 04:29 PM   #17
Tom
This is mounted to my swim platform. Ready for it to warm up a little more though.Click image for larger version
Old 02-09-2019, 05:58 PM   #18
Tom
Dbledan...I've looked online for one of these as an option but have been unable to find one. Do you know where I can find one?
Old 02-09-2019, 06:33 PM   #19
I have the same box and same situation, but its not a problem, ... that lid does keep the rain off the connection, if you use an extender, the connection will then be in the rain, ... but the link below is the adapter you are thinking about, ... it looks like to use this adapter you would still need to cut off the handle from the male end for the lid to close, ...
https://www.amazon.com/Camco-55205-1...8-1-fkmr0&th=1
Old 02-09-2019, 06:41 PM   #20
bob213's Avatar
Still have to cut the handle off the adapter....and then the connection between the two is really out in the weather.
You can avoid reality, but you cannot avoid the consequences of avoiding reality Ayn Rand
bob213 is offline   Reply With Quote
power
