Old 11-03-2016, 07:45 PM   #1
Honda 2000 plug questions
Hey guys, thanks in advanced
I just came across a smaller generator a Honda EU2000i which one have standard 120v plugs
Does like 13.3 Amps and I know my RV is 20amp plug
If I grab a plug to go from my 20amp to a standard 120v wall plug like generator had can I use this??? To change battery's on the camper for 12v fridge and also lights etc... I know it will not do the a/c but it's cold now so....
Thanks again
Ozziedodge67 is offline   Reply With Quote
Old 11-03-2016, 08:08 PM   #2
Flybob's Avatar
That will work, but I would run the fridge on propane ( 12V control board). The converter, CO/Propane detector, will draw some current. The 12V fridge ( if not on propane), converter, furnace fan may get you close to the breaker limit on the Honda.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-03-2016, 08:10 PM   #3
B and B's Avatar
X 2, good idea to move Fridge to Propane.I do that as well on Generator. Don't forget your Water Heater, that takes close to 10 amps.
Old 11-03-2016, 08:17 PM   #4
bikendan's Avatar
Your Wolf Pup should be 30 amp, not 20 amp.
Especially with an a/c.
Old 11-03-2016, 08:19 PM   #5
Should I grab a battery charger and just charge my 2x batteries with it thru the trip???
Or plug RV cable into gen and flip the breakers inside the camper so it just charges battery's???
Errr
16' Cherokee wolf pack 20pack10
Rzr 1000
Outlander 1000
•All pulled by 15' Gmc 2500HD duramax
Old 11-03-2016, 08:23 PM   #6
Sorry....
30amp yes
Rzr 1000
Outlander 1000
Old 11-03-2016, 08:27 PM   #7
B and B's Avatar
Ozzie.
You can use the converter, much slower than a external charger. Use a external charger to get it done faster.
I have this one,
http://www.batterychargers.com/sc-1000a/
Old 11-03-2016, 08:29 PM   #8
That is what I was thinking.... nice and easy.... charge the batteries and I can go a while
Rzr 1000
Outlander 1000
Old 11-03-2016, 08:30 PM   #9
tom39's Avatar
One of the generators I have is a eu2000i and it is a great little unit. As others have stated, if run your fridge and WH off of gas and you don't intend to use the AC, that generator will work out fantastic and be capable of handling everything else in your camper.
When I have taken mine boondocking, I was able to run all of my appliances (1 at a time of course) including my microwave, coffee pot, frying pan and even my wife's hairdryer and curling iron.
Hope it helps,
Tom G
2011 Rockwood 8288 SS UL
2011 Dodge Ram 3500 Laramie 6.7L
B&W Turnover Ball w/Companion Hitch
tom39 is offline   Reply With Quote
Old 11-03-2016, 08:31 PM   #10
Hope it helps,
Tom G
How did you plug into camper
Old 11-03-2016, 08:34 PM   #11
tom39's Avatar
RV dogbone adapter
Old 11-03-2016, 08:44 PM   #12
So did you use electric or propane on hot water
Rzr 1000
Outlander 1000
Old 11-03-2016, 08:46 PM   #13
tom39's Avatar
Propane
Old 11-03-2016, 09:06 PM   #14
Flybob's Avatar
The converter in your unit will do a better job charging the batteries than an external automotive charger. Also easier to use. The only exception is if the battery is very depleted where the inrush of current might blow the protection fuse.
TST Tire Monitors
2 100W solar panels
Old 11-03-2016, 09:41 PM   #15
bikendan's Avatar
I've been plugging the shore cord of my HTT, into my Honda 2000i for 10 years now.
The trailer's converter recharges the dual batteries easily and promptly.
No need for a separate battery charger.
To plug it into your Honda, all you need is a 30 to 20 amp adapter.
I use the simple hockey puck adapter I got at Walmart.
Old 11-03-2016, 09:45 PM   #16
tom39's Avatar
Honda actually makes a charging cord that plugs directly into your eu200i Click image for larger version
Old 11-03-2016, 10:17 PM   #17
bikendan's Avatar
Honda actually makes a charging cord that plugs directly into your eu200i Attachment 124629
Those are worthless compared to the converter or a battery charger.
Those 12v wires barely provide a charge would take hours to recharge a depleted battery.
Hooking up jumper cables from the tow vehicle, would also be faster.
Old 11-04-2016, 05:38 AM   #18
tom39's Avatar
Wow, that was aggressive! Sorry for offending or upsetting you but I wasn't comparing the cord to anything or other methods. I was simply providing information and an option for the use of the generator.
Old 11-04-2016, 05:52 AM   #19
bikendan's Avatar
sorry you took that as aggressive, i didn't mean it to be taken that way.
it's just that it's pretty well known on RV forums that the 12v wires for the Honda are a last resort use. they are very inefficient.
i apologize if you took it that way.
Old 11-04-2016, 01:08 PM   #20
The typical stock WFCO converter will take longer than a good dedicated battery charger because it will often not provide over 13.6 volts, even though it is supposed to. A depleted battery needs 14+ volts to recharge quickly, then goes to 13.6 and eventually to 13.2 as a trickle charge to maintain battery. Many of us have upgraded to a Progressive Dynamics Converter to get this multistage charging.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
