07-17-2011, 07:27 PM
Hot Battery
I have 12 volt batterys run together in parallel. While charging using the coach converter/charger one of the batteries is getting hot and I can hear it bubbling. The other batteries are cool to the touch. All connections are clean.
What's going on? Overcharge? Bad battery?
"If everything seems to be going well, look around, you've obviously overlooked something."
07-17-2011, 07:33 PM
Probably a bad battery. Are they all the same age? Are they all rated the same. They need to be rated at the same cranking amperage or the inverter will keep charging the smaller battery to bring it up to the larger rated battery which it will never get to.
DRINK COFFEE--do stupid things faster and with more energy ! Rockwood 5th wheel, Signature Untralite, 8244S
Tow Vehicle: Ram 3500 6.4 litre Hemi.
07-17-2011, 07:45 PM
The newest of the three identical batteries (140AH) is the one getting hot. It could have been defective from the get-go, I just never checked them before. Could be why battery life is less than I had projected.
07-17-2011, 09:01 PM
I had one that was doing the same ,,,,It was bad.
2009 Salem La 292FKDS--7600 lbs
2006 F250 fx4 Ext Cab,Diesel
(sold)2004 F-150 5.4 Auto FX4 3.73 Gears with Factory Tow Pkg, 36 Gal Tank, 96,000 miles ,Equalizer Hitch 10000 lb Bars ,MBRP 3in Cat-Back Exhaust SI/SO24 Days in 09, 35 Days in 10, 24 Days in 11,,23 Days camped so far in 12, 22 Days Camped in 13,,6 Days Camped in 14
07-18-2011, 01:03 AM
Newest of the three identical batteries......Post #2, "are they all the same age?" You can't replace just one at a time. Will always cause problems. Same thing with golf cart batteries. It is all or none.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
07-18-2011, 05:27 AM
A warm battery that is bubbling is not necessarily bad.
You might have to get a battery post disconnect switch and shut
it off when it gets warm and let the others charge.
Peace!
Dan & Rita D
07-18-2011, 05:46 AM
if u can disconnect that one battery and let the others charge, i would, then check the voltage on it abt an hour later.
i'm thinking the voltage will be down around 10v or less when u do. i'm betting that it is a bad battery also.
i go thru this with my truck every 4 yrs or so. batteries drag down while sitting over night. when i charge them, one will usually be hot. when checked, that one will be bad. unfortunately, when that happens the one that was good that wasn't changed, starts doing the same thing abt 6 mos later. if i replace it as soon as i notice problems, it doesn't appear affect the new one.
the single battery in the travel trailer will get hot while charging when it goes bad.
just tried (yesterday) to charge a battery for a UPS. after 1 day it was hot. checked voltage and it was 1.9V.
