Old 03-15-2018, 04:28 PM   #1
House batteries in motorhome leaking? Safe?
We have a 2014 Georgetown MH 328T. Noticed the house batteries were not staying charged and inverter not working. This is what I found. Looks like it's leaking? Needs to be replaced? Wonder if it's under warranty...how long are they supposed to last?
Lvnlife1973 is offline   Reply With Quote
Old 03-15-2018, 04:30 PM   #2
ID:	165305Click image for larger version
ID:	165306Click image for larger version
Old 03-16-2018, 05:08 AM   #3
Rich.M's Avatar
2-4 years is the usually all that can be expected from factory wet cell batteries . 4 years would be if they get excellent care( checking and adjusting each cell fluid level with distilled water every 4-6 months and maintained charge) . Looks like you may be boiling out a cell on the battery due to low fluid during charging. In any event they are end of life and not under warranty. Replace them , decide if you want to switch to no maintenance AGM or jump to lithium to power that inverter better. I would still confirm that the converter if putting out charge voltage and the bcc is charge voltage to batteries when coach running. Good luck.
2015 Solera 24r
2017 Jeep Wrangler
Rich.M is offline   Reply With Quote
batteries, leak, motorhome
