06-21-2022, 09:20 AM
How do I rewire an outlet to run with the inverter turned on?
The outlet my tv is plugged into isn't wired to the inverter. So what Ive been doing is running my generator or using a extension cord to plug the tv into an outlet that is wired to the inverter.
Can it be easily done? Can a moron like me be capable? We boondocks almost exclusively so id like to do this.
Or is it easier to buy a 12v tv?
2022 Rockwood Ultra Lite 2706WS, Dometic 12v fridge, 380watts of solar, 2 Lion Energy LiFePO4 105Ah batteries
1000watt inverter
2007 Ford F-250 Diesel CCSB tow pkg
Weigh-Safe WDH
06-21-2022, 09:49 AM
We do a lot of boondocking as well. My trailer did not come with an inverter. So, I added one. I bought an outlet (through Amazon) with a pre-wired extension cord and plugged it in to my inverter. I installed the new outlet in the cabinet below the TV. The new inverter is also located inside the cabinet behind my converter.
In your case, I do not believe you can rewire a 110v RV outlet (because they are not residential outlets) to work with your inverter.
Before I installed the inverter, I bought a cheap 150 watt 12v accessory inverter as I had a 12v outlet close to the TV.
Hope this helps!
06-21-2022, 09:53 AM
would be difficult to do since the wiring is inside the walls and the outlets are daisy chained. are the inverter outlets on a separate circuit from the rest? Is there an inverter connected outlet close by?
06-21-2022, 12:08 PM
I just plug the trailer into the inverter that way all the outlets are hot, just remember to turn off the converter beforehand.
06-21-2022, 01:06 PM
I nominate latner for the kiss solution of the day.
Just shut off any breakers you don't want to power.
Northern Indiana
2018 Salem Cruise Lite M-241QBXL
2018 GMC Canyon Denali
06-21-2022, 01:11 PM
How far away is the closest outlet that is on the inverter ? will have to look at ways to run the wire from TV plug to inverter run outlet and determine best route for wiring or is the inverter closer to the TV . many options to accomplish what you want
06-21-2022, 01:40 PM
Wow, you run an extension cord from the inverter powered through a door or window to plug the trailer into?
06-21-2022, 01:42 PM
If there is 12 volts available that close to the TV, then I would think that a small, like 150 watt inverter just for the TV would be an easy solution. I have a 300 watt inverter mounted in my entertainment center that runs the TV, a ROKU box, and a Raspberry Pi media server.
06-21-2022, 01:53 PM
On this topic of running TVs off inverters, how bad is it for the TV to use a modified sine wave inverter? It is all I have right now.
06-21-2022, 01:55 PM
Mine runs just fine on a cheap, Harbor Freight, 300 watt modified sine wave inverter.
06-21-2022, 02:08 PM
TV Power
I find the easier thing is to use a 30A to 15A adapter so the RV power cord will plug into the inverter.
NOW with that said, one will want to flip the breaker on the converter circuit to off. And one will want to be careful what is plugged in and switched on elsewhere in the RV. Thus all of the lights and outlets will be served by the Inverter. This may require a larger wattage inverter, but little to no wiring or modification, or switching is needed.
Just pay attention to power management and to battery voltage. NEVER let the battery drop below 11.9 volts.
We have a 750-watt pure sine wave inverter installed very close to the TT battery. Works just great for us.
06-21-2022, 02:19 PM
No, my inverter is mounted on the frame near the batteries when I need to use it, making it easy to plug the trailer into, then removed and stored when moving.
06-21-2022, 02:26 PM
X2
We use a 2000w mainly to make coffee early AM so not to disturb neighbors with the genny.
06-21-2022, 05:09 PM
That's weird....my lights are 12 volt DC. I thought all RV lights were 12 volt DC except for plug in table tamps.
06-21-2022, 05:29 PM
Same here. Bought a 2kw Renogy inverter and direct wired a 30 amp RV cord end with 10-3 SO cord -(heavy like shore power cord).
When I want 120 V AC I merely plug my shore power cird into the cird end from inverter and turn off converter, A/C, and water heater breakers.
Inverter is right next to my batteries with 2/0 cable.
This way I can run TV, DVD player, and use microwave to make popcorn or coffee if I want.
Note: I actuslly have three inverters I've accumulated over the years. A 300w, a 650 watt, and the 2000 watt. I have the option of using the smallest inverter for the task at hand to lessen the iverhead current or just plugging into large inverter and prividing whole house 120vac to all outlets and desired appliances
2004 Nissan Titan
06-21-2022, 05:30 PM
IMHO if you have to ask this question, you shouldn’t try it.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
06-21-2022, 05:37 PM
Hope this helps!
1000watt inverter
Weigh-Safe WDH
06-21-2022, 05:40 PM
The closest outlet on the inverter is about 8'-10' away, its above the sink in the backsplash. There is a closer one but its in the bathroom.
1000watt inverter
Weigh-Safe WDH
06-21-2022, 05:43 PM
Don't forget to switch off "Auto" on the 2-way refrigerator and, if you have one, the outdoor refrigerator.
TV: 2016 Ford F-150 SCrew EB RWD Lariat MaxTow
RV: 2020 Rockwood Mini-Lite 2507S
06-21-2022, 06:11 PM
I don't think I could do this with 2 young boys, they might be turning on and off things randomly. Though a good idea if I can be in charge of what on and off.
1000watt inverter
Weigh-Safe WDH
