Old 12-07-2022, 02:34 PM   #1
bubbalowe's Avatar
Hughes Autoformers won't work with generator
Got a Wen generator last year and it won't work with our Hughes 30 Auotperformer EPO, states loss of ground. Ran a wire from ground lug on front of generator to trailer frame, no luck. Sawed off a household ground rod and drove into earth and ran wire to gen ground lug, no luck. Is there some where beside trailer frame the generator needs grounded?
bubbalowe is offline   Reply With Quote
Old 12-07-2022, 03:45 PM   #2
On the generator, connect the negative/neutral terminal of the 120-volt output to the ground terminal of the 120-volt output.
You can buy a plug that is wired to do this. It is agenerator bonding plug. I made my own by using a standard 120-volt plug and added a jumper.
The EMS is looking for neutral and ground. Has nothing to do with external wiring or grounding.
Bob
Bob K4TAX is offline   Reply With Quote
Old 12-07-2022, 03:46 PM   #3
Most generators do not have a neutral to ground bond. Also unlike houses, most if not all RVs do not have a neutral to ground bond in the panel. Thus when using a generator it is necessary to add this bond. Google neutral to ground bonding for generators and you will see a method to do this. Use to you could buy the simple plugs pre-made but due to liabilities you may have to make your own now.
Custmachr is offline   Reply With Quote
Old 12-07-2022, 04:11 PM   #4
Retired Old Guy
IamProStreet's Avatar
This is what you need if you do not want to make your own. Just plug it in to the generator and plug your power cable to your trailer into the generator also.
Hughes Autoformers Ground Neutral Plug https://a.co/d/cyQm3Ph
IamProStreet is online now   Reply With Quote
Old 12-07-2022, 04:31 PM   #5
bubbalowe's Avatar
Thank you for all the answers!
Old 12-08-2022, 01:43 PM   #6
bubbalowe's Avatar
Ordered on Amazon $21.00
Old 12-08-2022, 03:42 PM   #7
Pseudonym
BrandonSmith's Avatar
Ordered on Amazon for $13... hmm
2021 Shasta 18FQ
2017 Ram 1500 Lone Star Crew Cab 5.7L HEMI
Attachment 251949
BrandonSmith is offline   Reply With Quote
generator
