04-11-2019, 12:12 PM
I feel the voltage
the other day I was adjusting the wdh brackets on the trailer frame and I could feel a tingle in my hands, tt is on concrete, I had flip flops and socks on standing in the grass, plugged into shore power 30amp down to 110 with a adaptor, so took a volt meter and measured from the tt frame to the ground and found 57 volts, no wonder it tickles, seems like a poor ground problem any idea from a electrician?
2019 FR Vibe 28RL
2018 Silverado 1500, Husky Centerline TS
3 Great Danes, 1 Weimaraner
Wonderful co-pilot
04-11-2019, 12:19 PM
What does that mean?
04-11-2019, 12:22 PM
Think he means....30A with adapter down to 15A. Plugged into standard household plug.
04-11-2019, 12:27 PM
Let's HOPE he means 30a R/V 110v outlet to 15a adapter and NOT 30a dryer/welder 220v outlet to 15a adapter!
04-11-2019, 12:51 PM
Commonly referred to as "hot skin" condition (actually the whole chassis) and yes typically that is a wiring issue.
*If* you are comfortable testing electrical circuits check the outlet for proper ground and that hot and neutral aren't reversed. Check the same after the adapter and at the coach end of the shore power cord.
04-11-2019, 01:06 PM
There is a sticky under the electrical forum for just this issue.
DYNAMAX 2016 FORCE HD
04-11-2019, 01:51 PM
Turn off the main breaker in the panel. Does this solve the problem? If not the short is in the incoming wiring. If it does solve the problem then the short is on a branch circuit. Troubleshoot those one at a time.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
04-11-2019, 02:32 PM
thank you the suggestions, and yes the other op on shore power, rv 30amp, conversation to a adaptor 15 amp, plugged into my garage 110v receptacle
2019 FR Vibe 28RL
Wonderful co-pilot
I will let you know of my findings
2019 FR Vibe 28RL
Wonderful co-pilot
04-12-2019, 12:37 PM
I had this happen to me too. Was pluggen into un -grounded outlet in garage (previous homeowner add). Swapped to another outlet and hot skin went away.
04-12-2019, 12:40 PM
I will try that this weekend because my garage outlet is a 2 prong, what's funny is my last tt was a 30amp and plugged in the same way with no issue, let you know later
2019 FR Vibe 28RL
Wonderful co-pilot
04-12-2019, 12:59 PM
This happened to me on my previous trailer.. Not the trailer's fault but found the outlet in the house I was plugged into was wire backwards..Buy a outlet tester at Home Depot and check your outlet plug >
Clint...
2015 F350 4x4 gasser.. 2017 Rockwood 2506S TT
Ardenvoir, Washington (near Wenatchee)
04-12-2019, 01:05 PM
I'll spare the deep details unless you care to hear them. This is not unusual. It's a grounding issue somewhere between the panel box and your trailer, possibly within the trailer. You need a GFCI outlet where you plug it in for safety in the event too much current flows outside the intended circuit (that being you.) It will shut off within milliseconds if this happens. And as an added measure of safety wear fully enclosed shoes and avoid standing outside and touching the metal portions of the frame. Even further you can have a grounded electrical service closer to the point where you plug it in. Code in your area may require this.
You mentioned it was a 2 prong outlet when you really need one that's got a dedicated ground (3 prong.)
Have an electrician handle this for you if your not comfortable taking care the issue. Your municipality may require one to do the work anyway.
04-12-2019, 01:08 PM
We keep this below as a sticky in this same subforum your thread is in. Mike Sokol, who is the absolute guru on these matters (and a forum member aka jmsokol) has much information on this.
Please read the following from Mike:
http://www.forestriverforums.com/for...-rv-89191.html
It will tell you how to find and correct your ground issue. We have this happen a lot.
If Mike sees this, he may chime in.
Here is a direct link to his great website:
http://noshockzone.org/are-little-shocks-ok/
2011 Flagstaff 831 RLBSS
04-12-2019, 01:14 PM
I had the same problem It was the 15/20 amp to 30 amp adapter.
04-12-2019, 01:26 PM
If your garage outlet is two prong, it may allow your adapter to be plugged in incorrectly (reversed) if the adapter was modified.
What 30a to 15a adapter are you using?
I've never seen one that didn't have a ground prong on it making it impossible to insert it into a two prong outlet unless the ground pin was removed.
04-12-2019, 01:37 PM
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
04-12-2019, 01:42 PM
Two prong means you have no ground.
I would replace the garage outlet with a good 15A outlet wired correctly and test again.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
04-12-2019, 03:24 PM
Originally Posted by dmayo32
You need a GFCI outlet where you plug it in for safety in the event too much current flows outside .
FYI...be aware this is not always a good idea with a RV. Often the GFCI in the RV will trip when plugged into another GFCI. While your logic is spot on just be aware there is often (but not always) issues with this.
Andersen hitch
04-12-2019, 05:08 PM
I understand the aggravating nature of GFCI/Arc Fault breakers and outlets. I've not had any issues with the 3 travel trailers I've had through the years yet. They certainly aren't a fix for bad wiring. But if something does become an issue it will catch it before you do.
I suppose if you can use one do, and if your converter, inverter, or other GFCI outlets cause issues well I suppose you don't have much of a choice.
I don't have a choice (technically) in my county.
BTW as you can see I'm new to this forum. We have a new Forest River trailer now, so "Hello!"
