Old 12-31-2016, 03:08 PM   #1
I have drilled into a wire going to the TV outlet...HELP!
While I was installing a shelf in a closet in our 2006 FR Surveyor model SV210 Travel Trailer, I drilled into the wire for the TV outlet (I rolled the dice and lost!!) All the power was on to the outlet so for sure the wire was shorted out. I checked the breaker to the outlet and, to my surprise, the breaker was not tripped. I repaired my stupidity (with all power off). I flipped the breaker back on and still had no power to the outlet. I double checked every breaker and fuse...still no power to the outlet. I resolved that I also had no power to the other outlets on the TV's circuit. I have verified with a multimeter, that there is no power to the TV outlet, or any other outlet on that circuit. I was aware of two reset buttons outside behind the hot water tank door, so I checked them, but they did not seem to have tripped. I am not sure if these buttons are for just the hot water tank, but I checked them anyway.
Where do I go from here?
Barry1 is offline   Reply With Quote
Old 12-31-2016, 03:26 PM   #2
grumpy0374's Avatar
Check your GFI outlets. You have to have at least one inside, possible two. One is usually in the bathroom area and another may be in the kitchen area. May also have one outside if you have an outside outlet.
Chances are the GFI tripped which is why the breaker didn't.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 12-31-2016, 03:51 PM   #3
KyDan's Avatar
What he said!!
Good luck!
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-41
Old 12-31-2016, 10:48 PM   #4
Thanks grumpy0374, it is now 10:40 PM and 28 degrees F so first thing tomorrow morning, I will check the GFCI outlet in the bathroom to see if it has a reset button. The GFCI that went to the wire that I drilled through, does not have a reset button. Your suggestion sounds very logical and I am hoping that this simple fix solves my problem.
I will certainly let you know in the morning.
Old 12-31-2016, 10:53 PM   #5
wmtire's Avatar
A true GFCI in the RV should have a test and reset button.
Sometimes you might see a label on an outlet that states 'GFCI protected outlet' which can mean there is a true GFCI outlet wired upstream of this one.
http://www.fehnelectric.net/plugs-no...r-gfci-outlet/
2011 Flagstaff 831 RLBSS
If I eat myself will I become twice as big?...or disappear all together?
Old 01-01-2017, 01:33 PM   #6
WolfWhistle's Avatar
... exactly like wmtire said. If the outlet doesn't have a test and/or reset its only protected... just like the label said. It is possible to drill into and break the hot or neutral wire without tripping a breaker... normally it does but not always
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 01-01-2017, 03:09 PM   #7
x3 on the GFI
mike.t is offline   Reply With Quote
Old 01-01-2017, 03:41 PM   #8
Thanks to all who took the time to give me advice on how to solve my mess, especially Grumpy0374. I reset the bathroom GFCI and BINGO!...life is good again. All joking aside, my last day of 2016 left me anticipating a $100 house call from an electrician plus labor and maybe a new converter. Now it is a good start to 2017. THANK YOU.
Old 01-01-2017, 03:46 PM   #9
grumpy0374's Avatar
Glad it worked out and was something simple.
100 bucks + labor!!!
Wow!!!
My charge will only be $50 bucks, total.
Just make the check out to "Grumpy"!!!
Have many safe trips and travels this year.
Grumpy
Old 01-01-2017, 04:56 PM   #10
Just don't forget, if you really did nick the wire, it could still be a fire hazard. Keep an eye on it.
D-Man is offline   Reply With Quote
Old 01-02-2017, 07:01 AM   #11
DouglasReid's Avatar
Grumpy
x2 And be VERY glad it was there. People get killed doing the mistake you did if the circuit doesn't have a GFCI on it!
ou were LUCKY!
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 01-02-2017, 07:08 AM   #12
He said he repaired it so I hope he used wire nuts to splice the cut ends, or even if it were just nicked. It would be best if a shallow box and cover were over the splice to eliminate the possibility of sparks causing an electrical fire too.
Nobody wants to burn their RV to the ground, particularly if they are inside at the time!
Old 01-02-2017, 11:49 AM   #13
camaraderie's Avatar
X2....you are at risk. Do not leave this to chance. Fish out the damaged section of wire...cut out the bad part...re-splice with nuts or crimps and tape over thoroughly.
________
Cam
2015 Georgetown 280DS
camaraderie is offline   Reply With Quote
Old 01-02-2017, 07:40 PM   #14
I certainly did short the wire out.
But I got lucky because it happened about 6 inches from the outlet box and there was about 12 inches of extra wire, so I was able to cut the wire at the short and reattach it directly into the box.
Thanks,
Barry1
Old 01-02-2017, 08:15 PM   #15
Mr. Dan's Avatar
Thanks,
Barry1
Thanks for returning and telling us about your solution. That helps us all in the long run.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 28; Booked = 50
led
