Old 04-21-2024, 12:51 PM   #1
Impact crimps are not reliable
I redid my RV system moving the batteries. While I was removing the existing 4/0 battery cables I noticed one of the wires was not tight in the lug. So I gave it a yank and the cable came out. I thought I had redone all my crimps with my Temco hydraulic crimper but must have missed one. So I went in the garage to test some of my redo cables that had impact crimps. I tried to pull out the cable from the lug on 4/0, 2/0 and 2 wires. Every one I could pull out. Some took some twisting and bending of the cable, but they all came out. I tested two of each size and none of them held.
Then I tried to pull out a Temco crimped wire from the lug. That sucker wasn't going anywhere. Beat the wire with a hammer with the lug in a vice and it would not move. Then I cut the crimp in half to look at it. Just one solid mass of copper. I remember reading somewhere that the hydraulic crimpers actually cold weld the whole cable. Compare that to the impact crimps where nothing was cold welded. All the individual strands were still individual.
I will never use an impact crimper and highly recommend no one use an impact crimper. The impact crimps are not reliable.
Impact crimper
2015 Chevy 2500HD 6.0 4x4 CC SB
2021 Salem Heritage Glen 290RL > GenY
1600W solar > 8400Wh LiFePO4 > Victron MultiPlus II > Cerbo GX
corn18 is offline   Reply With Quote
Old 04-21-2024, 01:56 PM   #2
When I bought my crimper, there weren't a lot of entry level choices that went to 4/0. I used the AMZCNC 12 ton hydraulic crimper. The device is fine. No leaks etc. and nearly as easy as pumping a grease gun but the dies aren't accurately sized and frequently had to use the next size down on half of the die, to get anything to hold.
2024 Surveyor 252RBLE
2023 F150 Powerboost 7.2KW 4x4 1658PL with a WeighSafe WDH
DJ252 is offline   Reply With Quote
Old 04-21-2024, 03:05 PM   #3
PhilFromMaine's Avatar
Like I said in another recent solar build post, decent tools will cost you around 100 bucks when you finish your project. I initially bought the impact crimper and came up with the same results as you. I ended up buying the hydraulic crimper that worked okay, but had a tendency for the dies to stick to the crimp.
2018 Coachmen Freedom Express Liberty Edition 231RBDSLE
PhilFromMaine is offline   Reply With Quote
Old 04-21-2024, 05:48 PM   #4
Good information. Thanks for sharing it.
2023 r-pod RP-192 with Beast Mode
600W rooftop solar, 300Ah LiFePO4 battery bank, 2000W inverter.
Uses an electric coffee maker when boondocking.
"Never underestimate the power of human stupidity."
-Lazarus Long
jlankford is offline   Reply With Quote
Old 04-21-2024, 06:22 PM   #5
I too bought a hydraulic crimper and found I has to use one size down.
Cutting a test crimp revealed a solid copper mass.
Just a guess but perhaps a more robust, plated lug, would not require using smaller die.
Only took one hot connector after a test run for me to invest in a hydraulic crimper.
TitanMike is offline   Reply With Quote
Old 04-21-2024, 07:06 PM   #6
I think it takes practice and testing. I used it exclusively. I used a three pound sledge, and a concrete floor. I did many test crimps using open ended lugs where you can see the wire on the other side, it should look homogeneous, hard to distinguish individual strands.
2019 F150 HDPP 4X4 3.5. 2500lb payload.
2018 Rockwood 2506
Half Ton Heavy is offline   Reply With Quote
Old 04-21-2024, 08:54 PM   #7
Blackrock's Avatar
I always used the impact crimping tool when I was running a field service truck and if you pay attention it works just fine. We had a big crimping tool at the shop that looked like giant bolt cutters and had changeable inserts in the jaws for different size cable.
It's like anything you do, pay attention and get it right.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Illegitimum non carborundum
Blackrock is offline   Reply With Quote
Old 04-22-2024, 01:19 PM   #8
nvs4602's Avatar
On sale just in time for this post.
https://go.harborfreight.com/email/2..._Over_25_Opens
nvs4602 is offline   Reply With Quote
Old 04-22-2024, 02:27 PM   #9
AND if you got a real good sold vice on your work bench they can be used to do a final ooomph to a suspect, whacked with a hammer crimp job.
use only real solid vices that can take a extension bar on the screw.
also seen some people make their own hydraulic crimper using a car jack and some scrap steel + the hammer crimper
if you got access to a 120 ton press... now that's overkill
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is online now   Reply With Quote
Old 04-22-2024, 02:30 PM   #10
PS... if you got a local West marine store
some stores have a crimper (bolt cutter style) that you can use
they have a good selection of quality marine grade lugs
Tarpon Springs FL
2022 Salem 24RLXL
Old 04-22-2024, 05:42 PM   #11
My advise has been use a big enough hammer! a 3 lb sledge with the tool sitting on an anvil, and I have not had any come loose. DR
dangerranger is offline   Reply With Quote
Old 04-22-2024, 10:56 PM   #12
Same deal having to use one size down, did about 20 crimps yesterday and found that my 2/0 needed 1/0 for a perfect crimp. My 4awg needed 6awg, also perfect. Thought I had it nailed down but all of my 6awg and 8awg crimps produced wings. Their appropriate sizes were too loose. No winning on those lol
hour is offline   Reply With Quote
Old 04-23-2024, 10:23 AM   #13
I found that if I crimped these sizes ising a multi step process the wings were a non-issue.
I start the crimp and only continue until the connector starts to grip the wire. I then release and rotate the partially crimped connectoe 90 degrees then crimp some more. If no wing is forming I'll go for max pressure. Might have to go a third time but usually that amounts to just knocking down a small "fin" for cosmetic reasons. I shrink tube all my wire to connector junctions so minor cosmetic defects are covered.
A note on "hammer crimps", when wiring bus bars or devices with limited clearance to adjacent insulators/separators (like in a Lynx Distributor, etc) a die type crimper that yields a nice "round" crimp is preferred. I've seen hammer crimps that are fatter and sometimes taller than the wire's insulation when completed.
Old 04-23-2024, 01:10 PM   #14
Exactly!
2018 Rockwood 2506
Old 04-23-2024, 01:31 PM   #15
This just makes me happy.
Old 04-23-2024, 02:14 PM   #16
Even with a hydraulic crimper I like to double crimp and do a tug test. When I say double I first crimp with the next size up die. Then crimp with the correct size. And don’t forget to use a heat shrink.
2015.5 Chevy 3500 DRW
2022 Impression 280RL
Touch racing is offline   Reply With Quote
Old 04-23-2024, 02:59 PM   #17
I went searching for the Temco hydraulic crimper in corn18's initial post. I find that there exists both a die and dieless version. Both are available on Amazon. The dieless version is much cheaper. A photo of a cutaway view of a crimped lug with the dieless indent crimp shows the desired solid "cold welded" copper mass - no strands visible.
So which crimper is preferred (I know, you're going the say the more expensive unit), and does the dieless version give acceptable results?
https://www.amazon.com/TEMCo-Hydraul...dp/B0813S6ZT7/
https://www.amazon.com/Hydraulic-TH0...dp/B00HJXHX1K/
-Lazarus Long
Old 04-25-2024, 05:56 PM   #18
rk06382's Avatar
If you are using 4/0 AWG the a 16 Ton Hydraulic Battery Cable Crimper is the only way to go.
I also purchased Windy Nation 4/0 AWG 10 Feet Black + 10 Feet Red Welding Pure Copper Ultra Flexible Cable.
The hardest part was cutting the cable ends. I had to buy a Southwire Utility Cable Cutter at Lowes because I could not wait on Amazon.
Hydraulic 4/0 Cable crimps.
Example of a bad OEM 6 AWG cable crimp.
Hammer crimp with heat shrink removed.
Repaired with Hydraulic crimped ends.
Cables installed:
Robert
2018 FR3 28DS | Boondock 99% of the time
Samlex EVO-3012 Inverter/Charger | 600ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | SnapPads | SumoSprings | Koni Shocks | RVLock
Solar Power & Battle Born batteries
rk06382 is offline   Reply With Quote
Old 04-25-2024, 10:20 PM   #19
Rixthe1's Avatar
I use rosin core solder, and a mapp gas torch, works great, every time.
Rixthe1 is offline   Reply With Quote
Old 04-30-2024, 09:00 PM   #20
Cables installed:
Was the hammer crimp done by a 98 year old woman? The crimp done properly will compress severely and leave an embossed X in the terminal. At least mine does. And there is no way you could pull the terminal off the wire.
You have to have the crimper on a very solid surface and whack it a couple times with a 3 pound sledge.
Itís one very major shortcoming is that it can not be used on a wire in camper, so if you need to crimp a wire that is already installed, you will need the hydraulic one.
2018 Rockwood 2506
