Originally Posted by Odie25
Hello we have a 2015 Salem Cruise Lite. The light fixtures above the bathroom vanity, bunk beds and bathroom all quit working at once. The bulbs are good. No blown fuses or tripped circuit breakers. Any help on troubleshooting and repair is greatly appreciated.
If the bulbs are good, have you checked for 12VDC on the lines feeding the fixture? For multiple to go at once, it's likely a fuse in your DC panel. You'll need a test light or multimeter to know for sure. Once side of the fuse should always have voltage. If the other side doesn't, the fuse has failed. You'd fail to see continuity across the blades of the fuse and it would read infinite resistance.
