Old 08-15-2013, 02:39 PM   #1
tom50mg's Avatar
Interior Lights and fridge quit working on 12v
Hi again everyone,about to take a trip and when I unhooked from shore power everything on the 12 volt side quit working,the slide works and landing gear work though! Any help,i checked all of the fuses at the battery area and fuse panel....06 flagstaff 5th wheel,thank,s.
tom50mg is offline   Reply With Quote
Old 08-15-2013, 02:55 PM   #2
Do you have a battery disconnect switch? Is it "on"? Slide and landing gear are often wired direct and will work with switch off, but everything else would be without power.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 08-15-2013, 03:03 PM   #3
Dave_Monica's Avatar
Look for a resettable circuit breaker on the power feed from the battery.
Dave
Old 08-15-2013, 04:37 PM   #4
tom50mg's Avatar
No 12volt.
Thank,s Dave and Bill,so far I have pulled out the circuit panel(converter) I found the black feed wire came out of the wire connector(marret).Thought for sure my problem is solved,soldered it together this time with new connector and still not solved,been following the feed wire forward to the source and the black and white feed wires go up the wall.Seems like behind the idiot panel to the right of the door opening,the only peek hole I can find is behind the tank andbattery meter,sort of stuck for an answer where to find a reset switch or breaker!
Old 08-15-2013, 08:56 PM   #5
The resettable circuit breaker should be very close to the battery...the reset is the small black button on the side as shown in the picture.
Dave
Old 08-16-2013, 08:11 AM   #6
tom50mg's Avatar
Hi Dave,the junction block,circuit breaker was not tripped,in the process of following the wires,behind a panel in the chest of drawers is a 30 amp bosch relay,no power going to it, the black feed wire from that junction box(circuit breaker)goes up the wall behind switches and display,don,t know where it goes from there,been trying to find a schematic without any luck there!
Old 08-16-2013, 09:06 AM   #7
tom50mg's Avatar
The black feed wire goes to the slide switch,now trying to find out where the green and yellow wires go to,routed under the trailer by the looks of it.
Old 08-16-2013, 09:32 AM   #8
The green and yellow wires that you're now tracing, is either one off the resettable circuit breaker near the battery...that will be the feed to the power center/converter.
Dave
Old 08-16-2013, 09:50 AM   #9
I went out and checked mine. One wire from the battery to one side of the resettable breaker...3 wires off the other side. Two of the three wires have in-line fuses...1 feeds the langing gear, the other feeds the main slide motor. The 3rd wire, a heavy gauge red wire feeds the power center/converter.
Dave
Old 08-16-2013, 10:36 AM   #10
tom50mg's Avatar
They seem fine,now I am trying to find the routing of that red wire that feeds the center converter....no power,maybe thats where I should have started!
Old 08-16-2013, 12:06 PM   #11
tom50mg's Avatar
I am having trouble tracing the red feed wire back from the battery to the center converter,however when I feed the converter directly from the battery everything works off of 12v.There must be another in line fuse or junction box that I don,t see!
Old 08-16-2013, 12:24 PM   #12
tom50mg's Avatar
Don,t see my last update,I fed the converter directly from the battery,everything works,there must be a junction box or inline fuse I can't find?
Old 08-16-2013, 04:57 PM   #13
tom50mg's Avatar
The feed wire (red) from the inverter goes through the floor,any idea where it goes,hope I don't,t have to start pulling the under belly down,the feed wire in front goes up into the framework,have no idea where that one routes to?
Old 08-16-2013, 08:06 PM   #14
Running new wire and abandoning the existing power feed may be the easiest at least for now.
Dave
Old 08-17-2013, 06:30 AM   #15
tom50mg's Avatar
I am just about done pulling my hair out on this one,usually the biggest headaches are the easiest fixs,but this one has proved me wrong...Thanks Dave.
Old 08-17-2013, 06:27 PM   #16
tom50mg's Avatar
Today I pulled down the front two belly pans,ran a new 8 gauge wire ,was not impressed with the wiring loom on the left side of the chassis just hanging there rubbing on the slide rails,clamped it all up to the underneath of the floor,clean out hose for the black tank never hooked up and left open at the top of the tank,if I happen to go to the frog rally next year I will be asking some questions.If anyone knows where that red feed wire goes please let me know,up from the battery into a frame rail.
Old 08-17-2013, 06:30 PM   #17
tom50mg's Avatar
Thank,s again Dave and Bill for your suggestions.
Old 08-17-2013, 08:09 PM   #18
Garrette's Avatar
I have done this. Use a analog volt ohm meter, that is what I have, get some automotive wire and make a long lead. The idea is to check continuity on the wire. The long lead will be just an extension of one of the leads on meter. Set the meter to ohms and test. If wire is the same, the meter will jump to the right, if the wire is known to be the same and does not read, there is a break in the wire, ergo, switch is open.
When looking for the same wire, you can test each wire and find it. If the wire tested has two or more continuity readings, just means there is another panel between the source and you..
Hope this helps,
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 08-17-2013, 08:13 PM   #19
Garrette's Avatar
You are checking for continuity so voltage does not matter, so no need to disconnect the wires. You could check voltage with the meter, but you are just trying to trace wires. Make a sketch as you go, at least it will be the start of a schematic of sorts.
Old 08-18-2013, 05:08 AM   #20
tom50mg's Avatar
Hi Garrette, I checked the continuity of the feed wire,there is none! I can not follow the wire because it goes up through the frame.That is why I ran a new circuit....
fridge, light
