Old 06-07-2020, 02:11 AM   #1
Intermittent fan noise
In my. 2019 Salem FSX 167rb the fan in the electrical circuit panel makes noise. Like it goes off and on or high then low. It did like that for about 30 minutes.
WFCO ULTRA III Model WF-8735
Jkhayes is offline   Reply With Quote
Old 06-07-2020, 04:59 AM   #2
bikendan's Avatar
probably the converter cooling fan running because it's having to work harder due to a weak battery.
Old 06-09-2020, 10:54 AM   #3
Intermitent fan in CB Panel
Thanks for responding. the Battery is good and the panel confirms it . this is a new Camper and is plugged in to my home. Since I had it it only was intermitent twice. No problem since I posted the problem.
Thanks for your support and be well
Jim Hayes
Old 06-09-2020, 11:03 AM   #4
‘And the panel confirms it’. Any display of battery condition will be overridden by the converter output voltage if the converter is plugged in and running. Some load (batteries, lights, heater, etc) was causing the converter to put out increased power and heat that the fan was trying to cool.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 06-09-2020, 12:00 PM   #5
NMWildcat's Avatar
I always worry if I DON'T hear my converter fan kick on occasionally!!!
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
Old 06-09-2020, 12:08 PM   #6
Intermittent fan
I am not using a generator. Camper is plugged into a 30 amp breaker in my shed.
Old 06-09-2020, 12:15 PM   #7
Fan can also run with lighter loads if the ambient temp is higher. It' temperature controlled.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
TitanMike is offline   Reply With Quote
Old 06-09-2020, 12:17 PM   #8
NMWildcat's Avatar
Converter doesn't care if the power comes from generator or shore power.
One sure way to get my converter fan running is when we turn on all the 12v lights
Old 06-09-2020, 01:37 PM   #9
bikendan's Avatar
Jim Hayes
The idiot lights on the panel, are not a reliable source and will always show full if you are plugged into shore power.
You need to unplug and use a multimeter or hydrometer to test the battery.
Old 06-09-2020, 01:45 PM   #10
Whenever we turn on 2 or more of the 12V lights, the converter fan comes on. I think it is working as it should.
KKonyha is offline   Reply With Quote
Old 06-09-2020, 11:23 PM   #11
Don't get a Power Dynamics converter then. Haven't heard its fan once since I upgraded.
NavyLCDR is offline   Reply With Quote
Old 06-10-2020, 07:36 AM   #12
NMWildcat's Avatar
You need to turn up your hearing aid then
It's amazing the things I hear when I turn mine up, some of them are actually real!
Old 06-13-2020, 09:15 AM   #13
And the voices are so much clearer......
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 06-13-2020, 11:58 AM   #14
One of the advantages of leaving the hearing aids out. And I don't need them for the voices in my head anyway....😉
fan, noise
