Old 02-24-2020, 05:24 PM   #1
Interstate SRM-24 Maintenance free???
OK, I'm actually embarrassed to ask this.
Just picked up our new trailer this week and I was pleasantly surprised to see the dealer actually installed 2 batteries. I didn't even request this. When I took a look there are 2 Interstate SRM-24 batteries wired together. Before joining this forum I thought that Interstates were a good brand to have. I generally have used Optimas when replacing batteries. It seems that all these brands are not all that good anymore(maybe??) so now I just go to Walmart. I know none of you guys would touch any of these for your RV, maybe some will for their TV.
Anyway, my previous trailer was clearly a serviceable battery with the 6 little round caps on top. Just like the battery for my sump, .... This interstate battery looks like every other car battery I've had/seen for 30+ years with just the 2 rectangular covers. Had I gone to AutoZone and bought this for my car I wouldn't have thought twice and just assumed it was the typical maintenance free battery. Since the RV dealer installed them on an RV I had expected batteries that required service. The Interstate web site doesn't seem to say either way.
I'm always plugged in when I camp or stored at home. I may leave it unplugged for several days when getting ready to leave and run the slides, jacks, etc,... as needed. So the batteries are abused, but I don't want to miss something simple like adding water while they sit doing nothing all winter.
Jim M.
2020 Flagstaff Super Lite 26RBWS
Former: 2017 Rockwood MiniLite 2104S
2015 Silverado 2500HD 6.0L Gas
jimmarako is offline   Reply With Quote
Old 02-24-2020, 07:33 PM   #2
A32Deuce's Avatar
There are other AGM batterys out there. I am trying 2 NAPA batterys now. 1 in my pickup at home and the other in my MH. Great so far. I got 9 to 13 years out of Optima batterys in the past.
A32Deuce is offline   Reply With Quote
Old 02-24-2020, 08:25 PM   #3
The SRM 24 is a wet cell deep cycle battery. It is not a AGM battery. I donít know if the covers can be pried open to add water or not. Usually these types have an extra water capacity designed to last the expected life of the battery. I would bet that those caps will come off, but I recommend contacting Interstate to see for sure. Jay
2016 Rockwood 2504s.
TV: 2014 Silverado 1500 double cab.
Jay2504 is offline   Reply With Quote
Old 02-24-2020, 08:29 PM   #4
bikendan's Avatar
What the dealer installed, were basic dual-purpose marine batteries. They are NOT true deep cycle batteries. They are a compromise between a starting battery and a deep cycle battery. I'll bet they have a CCA(cold cranking amps)rating.
Equalizer WDH
Old 02-24-2020, 08:36 PM   #5
Yes, they are 550CCA. Good thing they are not "starting batteries" thats a low CCA.
https://www.interstatebatteries.com/products/srm-24
I'm not looking for more work so if I don't have to check water levels, yea! Hopefully they last the 5-7 years my car batteries usually last. By then maybe lithiums will be more affordable and I'll go high tech.
Jim M.
Old 02-24-2020, 09:12 PM   #6
Blackrock's Avatar
I am running two of those on my 5th wheel and starting year number 5. Yes the rectangular cap comes off and you can add water Mine take a sip at the start of each season. The spend all winter plugged into shore power.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 02-24-2020, 10:01 PM   #7
If you regularly camp with electricity hookups and only use the batteries for short intervals like jacks, slides, water pump while using the bathroom during a pit stop while traveling, these batteries will serve you well. Even for a chilly overnight in a parking lot along the way.
The issue is really deep cycling like when boondocking for a long weekend without recharging (solar or generator) when they reachthe magic 50% DOD.
Unless you need more than 60 amp hours of use on a regular basis before charging I'd just use them as long as they last. They're maintenance free but it wouln't hurt to pop the cell covers (the rectangular covers in the center of the battery) once in a while and just look at electrolyte levels. Chances are you won't need to bother with water until they are worn out several years from now.
"A wise man can change his mind. A fool never will."
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 02-25-2020, 11:38 AM   #8
Thanks all. I'll worry about it in 5+ years hopefully.....
Jim M.
Old 02-25-2020, 11:49 AM   #9
NMWildcat's Avatar
The srm24 is a marine/rv deep cycle. Maybe it doesn't meet the requirements for the deep cycle purists, but they work fine. I use the 27 series in mine and they last 4.5 to 5 years. We boondock most of the time and according to all the forum experts, we abuse them horribly. They still last about 5 years, and they are cheap.
Happy RVing!
Scott and Liz - Southern NM
Old 02-25-2020, 12:26 PM   #10
Ejs4029's Avatar
Happy RVing!
X2....I've been using a SRM24 for almost 6 years now. I don't boondock and remove the battery in Winter and put it on a trickle charger. I would certainly buy another when it's time a for a new one.
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30C
Ejs4029 is offline   Reply With Quote
Old 02-25-2020, 12:29 PM   #11
NMWildcat's Avatar
Exactly. And the good thing about Interstates is that you can find them everywhere, even in Podunk USA!
Old 02-25-2020, 01:08 PM   #12
Tundra 2014
Battery
Where the adhesive strip is on top of the battery peels off to show the 6 caps. If I was replacing I would go to 2-6 volt golf cart batteries. Same cost, more capacity. Really depends on how much you boondocks, and how you handle batteries in the off season.
Tundra 2014 is offline   Reply With Quote
Old 02-25-2020, 04:12 PM   #13
DustyRoads's Avatar
If those are the same as mine they only have 64amp hrs each for a total of 128 amp hrs. If dry camping they will only last about 3 to 4 days. I will be going to 2x 6volt this spring. However, if you are going to be plugged in at campgrounds they will be fine.
2017 Forest River Surveyor 251rks
2016 Chevy 2500HD
DustyRoads is offline   Reply With Quote
maintenance
