Inverter circuits
Hello, and thank you for the reply. The unit is a
PD 1618 1800 watt Pure Sine Wave Inverter.
Update: Earlier today I had opened the outdoor main breaker and battery switch to look around, check for loose wires, etc. No luck. I put both back to the original positions. Later in the day the inverter circuits came back on line on their own.
I’d like to know what happened. The circuit failed once, it might fail again. Any ideas?
There is a shut down button on the unit, and an unlabeled button next to it with the graphic of a finger that I assume is the on buttton. I tried it, with no luck. The inverter had power in, but no power out. I’ll look online for a manual.
