Old 06-20-2021, 07:53 PM   #1
Tex_Raider's Avatar
Inverter error code
So we are new owners of 2021 Columbus 378mbc Fifth wheel, due to a hail storm that totaled our beloved travel trailer. We are completely new to the inverter world as our old travel trailer had a propane fridge. The inverter is showing a fault, and is giving us an error code of E-5. It is a progressive dynamics pd1210 inverter. In the manual it says to do a manual restart. I evidently donít know what that means, because I have turned it off and on and it doesnít clear the fault. Any ideas at to how to do a manual restart?
Trailer-2017 Wildwood 28CKDS
Tow Vehicle-2012 F250- Powerstroke
Tex_Raider is offline   Reply With Quote
Old 06-21-2021, 08:14 AM   #2
SeaDog's Avatar
You might try removing all power from the inverter by removing all 12V and see if that resits it. good luck let the forum know what you find.
Retired Navy
2016 Flagstaff 26 FKWS
Old 06-21-2021, 08:51 AM   #3
PhilFromMaine's Avatar
On my inverter (I don't even remember the brand), turning the inverter off, waiting a few minutes, and turning it on, is a manual reset. On some inverters you may have to hold the on button down for about 5 seconds or so. Make sure you have removed the electrical draw on the inverter before the reset or there is a good possibility you will get the same fault again.
On most inverters, the most common error has to do with the battery's discharging at a rate too high and shutting down power to the inverter. My inverter also has emergency shut downs for the same basic reasons.
My guess is that you are putting too many demands on the battery and or inverter. What were you running for appliances when it shut down. What is your battery-inverter setup.
PhilFromMaine is offline   Reply With Quote
Old 06-21-2021, 03:54 PM   #4
Tex_Raider's Avatar
I will try this out when I get home. Hopefully that will reset it. I Believe the only thing to be running off of it is the refrigerator. Nothing else should be on going down the road.
Old 06-21-2021, 10:10 PM   #5
Tex_Raider's Avatar
Update. I checked for loose connections. I found multiple loose connections at the batteries. I tightened all those up. Checked all connections to inverter, and they appear to be good. Turned the inverter off. Unplugged the refrigerator, and waited a few minutes. I still have the error code. My search continues.
inverter
