Originally Posted by Boborc
So you are saying turn off the converter by way of the breaker and leave the battery disconnect on/connected position? I assume this will also stop the battery charging?
This is how I run my trailer when boondocking. Leave batteries connected and turn off converter breaker in panel. Also a good idea to switch off the water heater and A/C breakers to prevent inadvertent operation while running Inverter.
If you disconnect battery while converter is off you will have no 12v power for furnace/thermostat, lighting, water pump, and other 12v operated items.
I plug my shore power cord into an inverter powered outlet which then powers up all outlets. I can run my microwave from a 2K Inverter with ease and have no desire to run A/C.
When off grid/boondocking battery charging is only available from Solar or Generator so unless you have either of both, don't worry about battery charging until you get back to shore power. Make sure you have a large enough battery bank to handle your off grid needs or invest in solar or generator.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
