12-02-2021, 09:20 PM
I like the woods
iRV36 Radio wired wrong
Huge surprise right?
The radio in my 2022 E-Pro E20FBS sounded terrible. I had noticed some threads on here mentioning that the factory frequently wires them up wrong, so I pulled the speakers and radio out to check.
The speaker ends were wired up properly, but on the radio harness they’d wired both interior speakers to the zone 1 left output and just hacked off the wires to the right speaker output.
I don’t really understand why this happens. It’s not like it’s any cheaper or faster to attach them to the wrong wires.
Anyone know where I can find replacement pins for this connector? They really didn’t leave enough wiring behind for me to splice on to.
12-03-2021, 12:43 AM
I like the woods
Originally Posted by NavyLCDR
I did send a message to the manufacturer, but I expect I’ll either never hear back or they’ll offer to sell it to me for way more than is logical. I was thinking it was probably something from Molex, but hadn’t had a chance to look yet. That sure looks like the right connector though. Good find, and thanks!
Maybe I’ll just order that and hook the various wires right to the pins. I hate splices that aren’t really necessary.
12-03-2021, 08:42 AM
Come back and let us know how that worked, because I was thinking the same thing about eliminating splices myself!
12-03-2021, 12:02 PM
Another possible option is to remove the pins from original connector and change out the wiring with some longer wires. On all of those connectors, the pins can be removed, it's just a matter of figuring out how to remove them...
2021 Wildwood FSX 190RT Toyhauler
2016 Chevrolet Silverado LT 1500 Crew Cab 5.3l 6L80 3.42 4x4
12-05-2021, 11:25 AM
Contact extractor
Contact extractors for these contacts are tubular tools. Most have a slot up the side. You fit it over the wire and slide it in from the back. The tube depresses the barbs on the connector and you pull the wire, contact pin, and extractor out together. On certain connectors, the extractor is inserted from the front side.
Amazon offers 485 (!) different ones. Just have to figure out which one you need. If you can't determine that, they have some 70-80 extractor assortments for $14-20. Just get one of those and try all the options.
My preference would be to simply strip the wire stubs, slide some shrink tubing on the new wire to be spliced, solder the connection, and then slide the shrink tubing over the joint and shrink it.
Larry
12-05-2021, 01:32 PM
Sound system output wiring correction
This is a problem that crosses models of trailers, years of manufacture, and brands of audio systems. Our 2020 ePro14fk has a Furrion audio system and had the two internal speakers wired in monaural, with the wiring harness leads clipped short. I was able to use the clipped wires to correct the speaker wiring to be stereo, but I did purchase a new wiring harness with connector and someday, I will probably clean up the remains of my splice.
The Furrion audio system actually has four separate 20 watt amplifiers, two for zone 1 (interior) and two for single zone 2 (exterior) speaker. I also replaced the stock internal speakers with actual 2-way coaxial speakers and added a small, powered subwoofer, since the Furrion has a subwoofer output.
We don’t need loud, we just want decent sound, and now we have it, for about $100 and some electrical work.
Forest River Flagstaff e-pro 14fk
Ford Escape Turbo
12-06-2021, 01:31 AM
I like the woods
I actually have a pin removal tool that works just fine on this connector, so we’re good to go there. I considered stripping and soldering the stubs, but it would bug me forever knowing that mess was in the wall. I’d rather redo it the right way.
It’s the reason I open up every space I can get into, vacuum out the sawdust and clean up the garbage, properly secure wires and hoses, fix screws that missed their targets, etc. I had to do the same thing when I had a $120k Airstream, so I fully expected it on a sub-$30k E-Pro. Sad we have to do it, but such is the life of an RV owner.
12-07-2021, 09:38 PM
I like the woods
My connector came in today and I headed over to re-wire the thing. I ended up not removing all the splices to wire everything straight to the connector as some of the wires were a bit short. The only 2 conductor cord I had on hand happened to be speaker wire, so I used that to run from the connector to the right hand speaker. It still sounds bad, but not as bad as it did. At least it’s wired properly now!
I guess if I want any kind of semi-decent sound I’ll need to replace the garbage speakers.
12-08-2021, 09:56 AM
Where you able to confirm + and - on the speakers?
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on a custom trailer.
12-08-2021, 12:13 PM
I like the woods
I was. The speaker terminals are labeled and the wire was striped on one conductor so it was easy to match up.
Jeremy
Current RV: 2022 Venture Stratus SR231VRB w/ 412Ah LiFePO4, 800w Solar, Victron MPII2x120, 60A DCDC
Current Tow Vehicle: 2021 Jeep Gladiator Mojave
Previous RVs: 2022 E-Pro E20FBS, 2020 Airstream International Serenity 30RBQ
Previous Tow Vehicle: 2020 Ram 2500 Limited CCSB 6.4 4x4
12-14-2021, 04:40 PM
I like the woods
I just heard back from RecPro about getting a replacement harness. As expected they said they can't help.
Glad I went ahead and fixed it without waiting for them!
Jeremy
12-15-2021, 05:13 PM
Our 2021 20BHS was wired the same way. I was able to get some splices on there but it was aggravating. It does sound better, but it does baffle me why they wouldn't just wire a speaker to each channel.
Probably a decision made above the line workers so they do what they are told.
2022 Freedom Express 257BHS
2018 F-150 XLT w/3.5L EcoBoost and Max Trailering Package
12-15-2021, 05:36 PM
Maybe...
Maybe one rogue worker wired both trailers.
Hanlon's Razor: Never attribute to malice that which is adequately explained by stupidity.
Larry
12-15-2021, 06:51 PM
I like the woods
Oh, I don’t think it’s malice at all. I think someone got used to wiring them up like that when they were using single zone radios with left for inside and right for outside, and no one bothered to adjust the instructions or training they’re following. Why would they? That takes time and money, whereas doing what they’re already doing costs nothing and the .5% of people that actually notice and care will just fix it themselves.
Jeremy
