Nobody except heavy duty marine, aviation, and trucks use 24V. 12V is the RV standard (actually ranges from 10.5 to 14.4V). There is no way you have 24V unless:
- you have 2 12V batteries mistakenly wired in series instead of parallel. One battery is not going to give you 24V.
- you have no battery installed, and your converter is really messed up
Neither of the above is likely. It is more likely to have a messed up meter or measuring voltage at the wrong points (AC wire(s) instead of DC wires).
Editing: just occurred to me that your USB ports might be wired into the AC, not DC.
Fred W
