Old 02-02-2014, 10:33 PM   #21
sherdep's Avatar
Rmack - those led's he has are 360 degree - there is a set of 3 led's on the back like what you see on the front - if they were the flat faced LED's then they would just be faced down
I am guessing that he is using the metal tape to reflect the light down or to protect the fixture from the minimal heat the LED's put out
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 02-02-2014, 10:48 PM   #22
Incheon, S. Korea
BigBaron's Avatar
Sherdep got it! The light is unidirectional this way and there are no dark spots in our trailer. I've tried flat panels and they were too directional.
Me, Julie, Lil' Barry, Faith, and OSD Fang
2012 Coachmen Clipper 126 - Don't even have a TV anymore.
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
Old 02-02-2014, 10:58 PM   #23
sherdep's Avatar
I had been experimenting with LED's and kinda found the right combo. I have a mixture of 921 bulbs and LED's but once I find the right bulb setup I will go all LED's
I have an assortment of LED's I bought from China - they were cheap enough so experimenting wasn't an issue.
I was recently looking at the flat panel LED's - 5050 cool white with 12 LED's and have seen the one's with 24 LED's - whats your take on them? pushed the light down and not out?
and I prefer the cool white over the soft white
Old 02-03-2014, 11:04 AM   #24
I assume we are switching to LED's to conserve battery life, and then, reduced heat. I suggest read up on the mfg. claimed lumen output per smd's per flat disc. I have found that; assuming claimed lumens are accurate, watt burns is lower as unit price increases. You can see pics of the different circuitry from the mfgs., some look way more elaborate, thus the claimed efficiency. If all your concerned with is the most emmitted light per smd, then go with the most 5630's rather than the 5050's on a disc. IMHO
2012WhiteSolera is offline   Reply With Quote
Old 02-08-2014, 04:40 AM   #25
Incheon, S. Korea
BigBaron's Avatar
The wattage used depends on the IC they use and how "hard" (amperage) they drive the LEDs. Everyone is different.
Old 02-14-2014, 09:18 AM   #26
sherdep's Avatar
I changed mine primarly for heat
not so much to save electricity but if I decided to dry camp it would save some battery life over the regular 921 bulb
Old 02-14-2014, 11:13 AM   #27
Kaadk's Avatar
Same as mine. I swapped out any toddler reachable lights to LEDs so the kids wouldn't burn themselves. Be aware that not all LEDs run cool. Some have onboard resistors and tend to run just as hot. Thankfully, mine didn't.
led, light
