The drivers are contained in the lamps themselves. There is only wiring in the ceiling.
Did the other lights stay dim after they went dim or did they brighten back up? If they're still dim then it's likely that you stressed a connection and it's almost open. It may be hard to find, but I'd start at the switch or first fixture and pull them and see if there are any loose connections.
Gotta go campin!
