The wattage depends on the LED strip.
I used to be kinda up to speed on this stuff a few years back, but since that project finished I haven't touched a thing with setting up LED's.
I don't suppose you know what LED's you have on your strip, do you? Without knowing exactly what you have, there's no way to know what your power draw is. If you can find a specification sheet, it would be most helpful. If you don't have the spec sheet, you could always just measure the power draw as well with a multimeter. Pretty easy to do if you have access to the wiring, which obviously you do if you're installing a dimmer. Most multimeters will handle a 10 amp load, well within the power draw you should see with the strip lights.
Otherwise, for your calculations, you'll just have to assume an arbitrary number on the high side, so that you don't overload your LED controller. But you are correct in your estimate range of 2 to 5 watts per foot... it just depends on what you have.
Brian & Becky
2018 Avenger ATI 27RBS
