LEDs and USBs
What is the direct LED replacement for our 12V 921 bulbs? I've read on the message board something about the LED replacements only being good to 12V but our units actually put out slightly more voltage so they can blow the replacements if you don't get a stronger bulb. Can anyone clarify which bulb I can buy to just plug in and forget?
On our unit there are the recliners where many folks have the couch. Unfortunately, there is no 120V receptacle over in that area, I'd like to add one in that area either above under the wall cabinets or on one of the slide-out walls. Has anyone done this? If so, can you tell me where you cut the hole for the self-contained receptacle, where you got the 120V power from, etc.?
I'd really like to put in a self-contained receptacle that has a built in USB charger but have not found one online anywhere. Has anyone come across one that has a USB and/or micro-USB port with the regular self-contained duplex receptacle?
Thanks!
2014 Sunseeker 3010DS on Ford Econoline E450 Chassis
Newly Retired!!!!
