Old 04-11-2015, 09:16 PM   #1
Light ,where's the switch?
This light on our 2015 Vengeance 25v...has no switch that we can find...looked in forward storage area... No remote... It's our mystery light...anyone have any insight?
2015 Vengeance 25V
campingwithavengeance is offline   Reply With Quote
Old 04-11-2015, 09:19 PM   #2
Might be labeled OS or DS on your panel.
Old 04-11-2015, 09:23 PM   #3
mark0224's Avatar
Looks more like a marker light, plug your umbilical cord into the tow vehicle and turn on the head lights I'm betting it comes on. Other than that I couldn't tell you, but you should have 1 on each corner going around the unit.Do it when it'ls starting to get dark these lights aren't very bright in daylight.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 04-11-2015, 09:35 PM   #4
It looks to me like a clear lens and on the front it should be amber if it is a clearance light.
Old 04-11-2015, 09:42 PM   #5
It is clear and this is the only one like it on the TT.
2015 Vengeance 25V
Old 04-11-2015, 09:43 PM   #6
mark0224's Avatar
Could be clear with an amber bulb, It is in a funny spot for a scare light they are usually in the middle of the unit. Also if not a marker there should be one in that area and there isn't.
Old 04-12-2015, 06:41 AM   #7
fonzie's Avatar
Is your light switch in the front bedroom by the door?
Fonzie
Old 04-12-2015, 11:14 AM   #8
No Fonzie... That switch is working the light above bedroom door...it is a clear lite with clear bulb...going to change bulb maybe it is out...just pick this unit up a couple weeks ago...and I am realizing that anything is possible with Tt's...
2015 Vengeance 25V
Old 04-12-2015, 11:57 AM   #9
Does it come on with something else like the porch light or is there a switch right on the housing itself? Is there another outside light with it's own control such as at the front by your jack that maybe controls this one?
Dan
2020 Chevy Silverado RST
2014 Surveyor Select SV 264
2020 - 4 Nights Camping - Covid and Surgery does that.
Beluga is offline   Reply With Quote
Old 04-12-2015, 01:02 PM   #10
No Beluga.. to all... It is the only light like this on TT. We are baffled, contacted the dealer where we bought this TT and no help there either...I am just wondering if is a light wired on the same switch in bedroom for the"porch" light and it is a blown bulb...
2015 Vengeance 25V
Old 04-12-2015, 01:07 PM   #11
dicky1243's Avatar
Its probably the what they call a scare light in the switch panel where all the awning,pump, sewer tank, step light etc. are on.
2006 Gmc
2016 Forestriver Sierra 376 BHOK
Full Timers
Dick,
dicky1243 is offline   Reply With Quote
Old 04-12-2015, 01:17 PM   #12
I just pulled up some pictures of other 25Vs and they have that light also. Maybe your until was built on a Friday and they forgot the switch?
Wallace
twiggw is offline   Reply With Quote
Old 04-12-2015, 01:17 PM   #13
fonzie's Avatar
X2, look into this panel if you have.
Name:	RV control panel.jpg
Fonzie
Old 04-12-2015, 01:32 PM   #14
Timex's Avatar
Kind of small for a booger light. But it might be on this model. If it is, I'm like everybody else, the switch should be on the panel by the door. If it's a clearance light, it needs to be plugged in to the TV. Or put a fuse in the cord to make the lights come on.
Also, I would recommend that the OP gets a gutter spout extender so the water will not pour directly on the lens. That much water is not good for a light.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 04-12-2015, 02:08 PM   #15
Also, I would recommend that the OP gets a gutter spout extender so the water will not pour directly on the lens. That much water is not good for a light.[/QUOTE]
Thats probably whats happened , water has gotten into it and bulb is blown.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 04-12-2015, 02:16 PM   #16
Hey thanks all, I will look into gutter extension...anyone have a good link for them? Will change bulb and go thru all suggestions until switch is found!! And LOL Twig! We were joking about that, hoping that's not true tho!!
2015 Vengeance 25V
Old 04-12-2015, 02:21 PM   #17
Originally Posted by Timex View Post
...If it's a clearance light, it needs to be plugged in to the TV...
I think it's been established it's not a clearance light with a clear lens and a clear bulb by the OP.
Old 04-12-2015, 03:32 PM   #18
spierce617's Avatar
Here is a link to the gutter extensions from Walmart.
Camco Mfg. Inc./RV 42123 RV Gutter Extensions-4 PK GUTTER EXTENSIONS - Walmart.com
When you change them out make sure you put some butyl tape behind them before you put the screw in. That will make it so they do not leak through the screw hole.
2005 Winnebago Adventurer 38R
Workhorse 8.1/Allison Transmission
Old 2005 Forest River Cherokee Lite 28A
spierce617 is offline   Reply With Quote
Old 04-12-2015, 04:27 PM   #19
Timex's Avatar
I used the cheap extensions on my last TT, wooden clothes pins! Worked like a charm.
And I am serious.
Old 04-13-2015, 10:45 AM   #20
I think it may be a motion-sensor light.
Terry & Carla
2018 GMC SLT Duramax
2014 Bay Hill 320 RS
terry.e is offline   Reply With Quote
light
