Originally Posted by Crockett
the OP stated voltages ..i.e.meter. i dont care about the amp draw of the 80 amp. fuses blow, automatic circuit breakers trip and reset even if imbeddedin a power converter...
YOU suggested a convertor that the op would have to run a new circuit to even use.
And it could possibly use up another precious 5 amps worth of incoming power.
I've been down this road many times and not once has it been anything other than a bad battery or a convertor when the lights dim and then get brite.
TURBS
