Old 04-04-2024, 10:45 PM   #1
LiPo battery charger
I’m sure this has been asked a millions times but what type of charger do I need to top off LiPo batteries. As I understand my solar and the built in RV converter (shore power) can charge up to around 80% then I need to charge with another charger for LiPo ?
Could someone link me to a mid grade charger?
I have these batteries from Amazon.
Power Queen 2 Pack 12.8V 100Ah LiFePO4 Battery, Built-in 100A BMS, Lithium Battery 2560Wh, Up to 15000+ m
Thanks!
WolfPup2018 is offline   Reply With Quote
Old 04-05-2024, 07:24 AM   #2
Any charger with a LiFo setting will work. Mine has a button that toggles thru 4 battery types , LiFo being the last one. Does your solar charger have a LiFo setting, if so you should not need a separate charger. If not you could just replace it with one that does, then you don't have to deal with a separate charger.
2017 Wolfpack 315 Pack 12 5th wheel Toy Hauler
2013 F250 6.7 Diesel Dually 4x4
Odyknuck is offline   Reply With Quote
Old 04-05-2024, 07:36 AM   #3
This is good advice.
2024 Surveyor 252RBLE
2023 F150 Powerboost 7.2KW 4x4 1658PL with a WeighSafe WDH
DJ252 is offline   Reply With Quote
Old 04-05-2024, 08:04 AM   #4
Iíll have to check the charger, I believe it does. What about amperage for the charger? I did see the IP22 30a charger, but it was close to $200
Old 04-05-2024, 08:04 AM   #5
How do you size the charger? In terms of Amps?
Old 04-05-2024, 08:47 AM   #6
Your on board converter, even if not lithium compatible, will do most of the heavy lifting and then your solar controller, if lithium compatible, will do any of the finishing you'll need.
Old 04-05-2024, 08:54 AM   #7
Thanks. Looks like my controller does support it.
Wanderer Li 30A PWM Charge Controller
Old 04-05-2024, 09:29 AM   #8
We needed a new charger.
We purchased the Victron 15 amp. Expensive. $150
It has special design to awaken sleeping bmsís. Something that is likely a good idea.
tomkatb is offline   Reply With Quote
Old 04-05-2024, 09:31 AM   #9
PhilFromMaine's Avatar
That is a top of the line charger, maybe a Victron. There are a lot of good chargers that are a lot cheaper.
Your solar will charge your lifepo4 battery to 100 percent if it has a lifepo4 setting. I would upgrade your solar controller to a MPPT solar controller. A middle of the price range good MPPT should be around 120 dollars.
2018 Coachmen Freedom Express Liberty Edition 231RBDSLE
PhilFromMaine is offline   Reply With Quote
Old 04-05-2024, 10:39 AM   #10
EpEver tracer 100/30 is $89.99 on Amazon. Works great for me.
All things considered (I added a MP50 remote display for another $32), now that’s very close to a Victron 100/30 smart solar with Bluetooth. Their minimal display model Bluesolar is $112, $30+ for their Bluetooth dongle).
Victron SmartSolar 75/15 is about $80 with Bluetooth IF you can series parallel your panels to not exceed the 75 volt and 15 amp input limits.
I still track the 100/30 & 75/15 Victron on Amazon. I may switch if the price tempts me to during Prime Days.
My current EPEver 100/30 works great, I’d have preferred Bluetooth vice wired display but the EPEver Bluetooth dongle had a lot of problem reviews. If the unit is easily accessible for viewing, it does have an excellent detailed display. I have mine in the forward pass through, display kinda visible ;(.
My Solar, all 200 watts currently mounted, have no problem topping off and equalizing my 4 batteries. TT has pre Lithium converter.
I have two more 100 watt panels awaiting warmer weather for install. So 4 100 watt panels is all I’m planning on. I can skate by with my current SCC with all four in parallel or drop down to the Victron 75/15 with panels in 2S2P configuration.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, SumoSprings, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
Boomerweps is offline   Reply With Quote
Old 04-05-2024, 12:13 PM   #11
Some lifepo4 battery mfrs will recommend using the AGM profile if there is one and no "lithium" profile. Provides the higher voltage desired for fully charging lifepo4 batteries and cell balancing. They feel it's close enough and better than just a FLA profile.
TitanMike is offline   Reply With Quote
Old 04-05-2024, 12:21 PM   #12
What boomwerps said
Get the solar setup make sure it is set for lifepo4
Last night used about 50ah Cracker Barrel parking
1pm today 100%……… driving up to Ohio
Been using slides jacks heater and 12v fridge
Your results will vary depending on location and size of your solar panels
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
battery, charger
