07-28-2022, 05:07 PM
Lithium Battery warranties and returns
I just had a lithium battery under warranty stop accepting a charge. IMO it has to be a BMS issue. I called the original seller in another State and followed his diagnosing and repair instructions to no avail. When I mentioned the warranty, he said okay, "mail the battery back to me" (at my expense) and he will look at it. He never gave me any instructions on how to go about it.
Numerous emails later, the original seller still hasn't given me specifics on how and where to ship a lithium battery. I tried UPS and they flatly refused to ship it for me. I noticed BattleBorn Batteries will supply you a pre-labeled box with all the necessary warnings for a fee that will allow their batteries to be shipped via Fedex whom they purportedly have a special agreement with.
My question is: does anyone have any actual experience returning a lithium battery, other than a BattleBorn, that they could share? I am starting to believe these cheaper brand warranties are worthless.
07-28-2022, 05:34 PM
ooof - Sorry for your experience.
UPS has provisions for shipping lithium batteries, as do most of the other major carriers.
Some questions, so that we might benefit from this:
1. What brand battery is it?
2. Is the 'original seller' a manufacturer, a manufacturer's rep, or a distributor (or simply a previous owner of a used LiFePo)?
3. What are the terms of the warranty (timing)?
Sorry again, amigo.
2022 Rockwood Roo 235S
15kBTU AC; 12v fridge; 1kW roof-mounted solar panels; 80 amp MPPT charge controller; 3,500w pure sine wave inverter; 30a automatic transfer switch; MicroAir EasyStart, 600ah Chins LiFePo; Honda EU2200i (with Hutch Mountain propane conversion kit) gathering dust in the storage unit.
07-28-2022, 07:03 PM
by
Sorry again, amigo.
Thanks for your reply!
1. Rebel Batteries
2. All lifepo4 batteries are made in China by a few manufacturers and then re-branded by distributors.
3. Warranty is something like 5 years (from memory)
I believed the battery initially arrived via UPS. So they do deliver batteries. However, apparently distributors have special arrangements with the shippers pertaining to packaging and the appropriate warnings on the box, etc. I was unequivocally told by UPS that they would not ship my battery. This was both at a UPS Store and at the mother UPS company office.
BB's site also makes it clear that their relationship with Fedex is one where they have worked out all the issues involved with shipping lifepo4 batteries.
I read your reference sites verbiage, but in the trenches at the UPS counter, I was denied service twice.
My point is that without a sincere effort by the distributor-seller to give you an achievable path to return it, a single individual is going to meet stiff resistance when trying to ship lifepo4 back to the seller.
07-28-2022, 07:23 PM
All I can add is that you usually get what you pay for. I'll bet your battery was a lot cheaper than BattleBorn, wasn't it? And now you know why. By the way, BattleBorn batteries are not made in China and rebranded. BattleBorn batteries are munufactured in their own plant in Reno, Nevada.
07-28-2022, 07:47 PM
I have bought lithium batteries from individuals online and have received them from UPS. One order was 400 lithium ion 18650 batteries. The other was 8 lifepo4 cells. I still have the boxes if you want pictures for how to ship. You have to have the box labeled properly. Also proper packaging is a must. A wood box is best. But a heavy cardboard box lined with 1" thick foam will also work. I attached a warning label, on the contact line put the sellers contact #.
It all else fails look on YouTube, chances are someone has taken one apart and done a video. Replacing a BMS is pretty simple.
Here's a link for a 100amp bms from battery hookup
https://batteryhookup.com/collection...ow-temp-cutoff
07-28-2022, 09:04 PM
I guess if it come to fixing it yourself I could walk you through it. Or come plug in at your house we've wanted to see Maine. The wife's could shop and we could fix your battery.
Good luck, keep us up dated.
07-29-2022, 07:54 AM
I did investigate this once. So unless something has changed, all the parts are made in China and at best assembled in Utah. What I recall seeing on Youtube from BB was that they have the batteries built in China and that they inspect and do quality control in their place in Utah. That, as I remember, was a couple of years ago on Will Prowse's Youtube channel.
07-29-2022, 08:11 AM
I took your advice and searched Youtube for information. I found a site I regularly follow and found this video.
Summarizing, the video states that as an "everyday Joe" shipping a lifepo4 battery is insanely difficult to do and may lead to a 75,000 dollar fine if done improperly. Larger companies that ship these items all the time usually have a full time licensed service that does it for them. Of course some companies like BB do it in house.
You, as an individual, may cheat the system and do it, but if you get caught the fine could be hefty. Most likely the internet retailer has all the certifications and packaging so it only makes sense that if they are sincerely going to take back a battery they would supply you the packaging under their company name. If they won't up front do this, their warranty is a joke.
07-29-2022, 08:18 AM
Thanks for the offer. If I still had a house you would be more than welcome to hook up and use it as a base, but as of 2 years ago, I am living in an apartment. I have to rent a storage space for my TT at 125.00 per month.
My lifepo4 is weather proof so opening it will negate that. However, I just may do that and remount the battery inside the TT. Thanks for your help!
07-29-2022, 12:56 PM
A hefty fine could well be the least of one's problems if they cheat and get caught.
The regulations re: shipping "lithium batteries" came about after several Air Crashes that were found to be the result of "lithium batteries" in their cargo.
https://www.ainonline.com/aviation-n...some-accidents
If such an incident was traced back to someone who improperly shipped a "Lithium" battery just think of the civil liability one faces beyond any criminal charges and fines.
The shipping issue that arises when one has a warranty problem with a LiFePo4 battery makes Customer Service and even bigger factor when deciding on purchasing. Might be worth the effort to inquire how the company handles the defective battery and who pays? Do they send a "return kit" (like cable companies do with packaging and labels)?
Some may find that that low cost Lithium battery has so many obstacles to obtaining warranty service/replacement it's just a disposable battery.
07-29-2022, 08:30 PM
This was with lithium ion batteries which are more hazards than lifepo4 batteries. They have to be shipped ground shipping only.
07-29-2022, 09:11 PM
My Battle Born LiFePO4 were shipped FedEx air after they were discharged to 25% SOC. It was the only way to get them to Alaska.
Battle Born are worth the extra cost.
07-29-2022, 10:09 PM
I have read a lot of forums on lithium ion batteries. And seen the development of a capacity tester for 18650 lithium ion batteries like found in laptops. It could test 16 batteries at a time and log the data to a computer. One of the parameters of this tester was to discharge each cell to a specific voltage so they could be shipped. batteryhookup.com a big supplier of used salvaged cells requested this as part of their input and investment in the beginning of the crowed funded project.
So I've been building my own battery packs for several years now the biggest one I used 840 lithium ion 18650 cells to build a 316ah 24v battery. Now I build my own lifepo4 batteries too.
08-01-2022, 10:58 PM
Open Space Wanted
Designed and assembled in U.S. Cells are chicom like the others but with more QC?
Another U.S. company assembled in CO.
Part of their 10 year warranty for returns.
Customer pays return shipping on returns or warrantied component inspections. Please note some battery returns may require special documentation and packaging, and these instances will encounter extra fees. This is in order to correctly comply with lithium battery shipping regulations. For all return shipping we recommend using a local shipping service like FedEx office or the UPS Store.
https://www.enduropowerbatteries.com/pages/warranty
08-02-2022, 07:57 AM
And BattleBorn most importantly will supply the return box and inserts with all the documentation needed. And like I said, I was assertively told NO WAY by UPS. BB in another section of their WEB site stated that they had a special agreement with Fedex to ship their batteries. For those who don't know, "chicom" is an acronym for "Chinese communist".
That is the type of support I expect from my supplier, but at present time it looks like I am not going to get it. Any communication is like pulling teeth. I will give them a couple of more days, but then the battery goes to the hazardous waste collection at my expense.
What I would have expected was a telephone conversation with an attempt to diagnose the problem by having me do certain rudimentary tests under his direction and then a decision by him to have me return the battery and his honoring the warranty. It apparently is an issue with the BMS. I get it! even the best BMSs will occasionally fail, but that is, or should be covered in the warranty.
08-05-2022, 08:30 PM
Final resolution
Update: Eraic of Rebel Batteries refunded me the cost of the defective battery. I just wanted to set the record straight that Rebel Batteries of Austin, TX stood behind their product.
08-05-2022, 08:37 PM
Thanks for the update. Glad they stood behind their product and refunded you the cost.
2015 Dynamax REV 24TB class C
08-05-2022, 09:46 PM
Good to hear that. And thanks for the update.
08-11-2022, 06:21 PM
I agree with some warranties are useless.
The money you save purchasing an item far from home (usually through shipping) that has a long warranty, probably won’t be worth the savings when you need a replacement.
I believe with lithium batteries, it’s best to buy a brand name locally. You get what you pay for.
Good luck.
08-11-2022, 11:26 PM
From imported cells
