03-10-2021, 02:28 AM
Looking for help identifying these electrical parts
Looking for help from you electrical wizards as to what these key components are here in my battery box. I do have an emergency battery jumper from the cab to the coach and maybe one is a controller for that. The one in the middle I believe is a large fuse? Is the rack on the left a row of four fuses or relays? Not super up to speed on all electrical. Any help is appreciated. I believe it should all be factory set up. Battery box is next tray to the right.
2018 Coachmen Concord 300DSF
2018 Jeep Wrangler JK Toad
03-10-2021, 08:50 AM
This is what they appear to be. The buss (a common tie point) is just for distribution to various 12Vdc items.
03-10-2021, 11:51 AM
Would the Buss be a good point to tie in electrical accessories? Eventually I will get a shunt an a Victron controller.
03-12-2021, 11:37 AM
It looks like it would be robust enough to handle additional accessories. Be sure and have bare metal to metal contact with the buss for your terminal lugs. Also might want to check under what conditions the buss is powered.
03-12-2021, 12:11 PM
The "Bus" actually looks like four ganged 12 volt auto-reset breakers. The "feed" side is a bus bar, so you could possibly add a couple light loads to it, but you need to add up the values (amps) of the four breakers to see how much possible load is on it already.
Gotta go campin!
03-12-2021, 01:24 PM
Based on the feed from the large fuse it looks like the top right is the feed with that breaker being the largest based on the wire size that is attached. Also looks like a pair of fuses going from the red wires to the white striped wires.
03-12-2021, 01:48 PM
The Victron Shunt has to be connected to the Ground side of the Batteries and all current must pass through it to monitor State of Charge, Current Flow etc.
The DC Bus can support any low draw 12V devices based on what it is designed for, wire size etc.
2016 Dynamax Isata 3 24FW
2016 Jeep Willys JK
Yellow Lab Buddy Biscuit Eater
USN-RET/DOD-RET
03-12-2021, 03:15 PM
By cracky, you are correct; I see that now. The one side is a feed from a 250amp fuse but don't know which end and so the top buss could possibly be used for additional loads but don't know when it is powered. The buss feed wire appears to be of a large AWG size but photos can be misleading without a reference.
03-12-2021, 08:20 PM
Got the buss bar, the other "Little Fuse 250 amp" is what is called an ANS Fuse. Usually used in a large electrical draw situation instead of a circuit breaker.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
03-13-2021, 01:19 AM
Yes it does look like 4 individual boxes under the one shared bar on the top. I didn't want to pull it apart to view the writing on the four units.
03-13-2021, 01:34 AM
I did run a blue 36 inch LED light strip at the bottom of the RV over the step. Wanted to light up the step better when on manual override, that shuts of the step light. I tapped a 12volt wire source on the outside of the battery box and put a 1 amp inline fuse to be safe and then a manual on / off toggle to turn on at my liking. You can also see my red, white and blue LED string on the ground. Some nice light, but not too bright for the neighbors.
