07-04-2022, 02:14 PM
Growing Older But Not Up
LP Gas detector????
Ok here another one I’m going to assume, since there are no lights on at all, that nobody is home. No operating light, no alarm light no fault light. But what’s the deal with the plug coming out from the bottom? I did install an additional smoke / CO2 detector in the bedroom is that sufficient or do I need to get this LP gas detector working ?
Steve Johnson
2004 26’ Forrest River Sunseeker
“Growing older but not up”
07-04-2022, 02:57 PM
General Rule
As a general rule, you want a working propane detector. Propane is heavier than air, so it will stay toward the ground. If you have a leak, it may be a while before you smell it, and it would be really dangerous.
As to what are the wires sticking out below it -- my guess is that they have nothing to do with the propane detector and were just a convent place to run wires into the living area for the previous owner.
2018 Flagstaff Micro Light 21DS
2018 Ford F250
07-04-2022, 03:10 PM
Best thing to do is remove the detector and see if it is connected to power and check if there is power there.
Yes, you do need an operating propane detector.
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
07-04-2022, 03:45 PM
That connector looks like something someone added. I do not see it in this PDF: http://www.gulfstreamcoach.com/media...770-Manual.pdf
Yes, you need a functioning propane leak detector.
Ray
2020 Georgetown GT5 34H5
07-04-2022, 04:08 PM
^^^^X2. Looks like they might have disconnected the wires to put in that green thing that looks suspiciously like a charge port.
2015 Dynamax REV 24TB class C
07-04-2022, 04:56 PM
Yeah I don’t know what the jumper is but I unscrewed the LP detector and it jumped off the detector wires. Havnt PUT a volt meter on it yet to see if I have any power.
Steve Johnson
07-04-2022, 05:45 PM
So the detector was not connected to the power wires?
07-04-2022, 06:24 PM
No it is but that jumper that comes out from underneath is wired into the detector. But the detector does not seem to have power
Steve Johnson
07-04-2022, 06:47 PM
Wondering if the previous owner lost power at the wires to the detector and that plug was their way of powering the detector.
07-04-2022, 06:50 PM
I hope not - that would mean re wiring the whole damn thing
Steve Johnson
07-14-2022, 01:28 PM
Did you get the problem resolved?
07-14-2022, 02:13 PM
LP detector like the one pictured has a service life of 5 years. This one is long expired. After that it stops working properly. I don't know the symptoms but these BEEP with low battery voltage and one way so stop the beeping is to disconnect them.
Don't know what that connector sticking out is for.
Detector needs to be near the floor. There are replacements available. Google the model number. Pull this one and measure the size of the opening. Mine is long expired as well so a new one will go in in later this summer.
-- Chuck
