Originally Posted by CampingNewbie
I probably won 't be boon-docking. Never realized there were fuses inside the converter - checked all the ones on the fuse panel and they were good, so were hte breakers. I will crack open the converter and see what's there. Thanks, learning more each day!
They're on the body of the converter.
https://rvcomponents.visonerv.com/cg...md/M3202/s4.pl
This is a VERY old 55 amp charger/converter that is single stage and WILL shorten the life of your batteries if left in full time in one spot. If it is a fuse problem...you can use it but suggest you pull the plug when your unit is no in use so as not to overchage your battery and ruin it over time.
You don't need this big a charger for park use...but you do want a smart 3 or 4 stage charger that you can leave plugged in... like this
https://www.amazon.com/DLS-15-AUTOMA.../dp/B007AGB9GG
That's the smallest IOTA and is fine for a single house battery system, Get the 30 amp model if you're carrying 2 house batteries. Similar quality chargers available from Progressive as well. Your choice if you need to replace.
Just a side note for others...wet cell batteries will accept a maximum of 25% of their rated amp hours. Getting any bigger than that will not improve charging time but will make your wallet lighter. If you don't boondock...a model that is left plugged in will be fine with a 10% of rated amp hours charger.
