Originally Posted by TheMarkles
It sounds like I had brownout, my bad for not realizing it, just lucky I didn't toast a circuit board somewhere. Not really sold on the softstart yet, especially since prices range from $80 - $400, seems a bit of a wide spread for basically a capacitor. I'll check the forums, maybe someone here has done a review on a few of them.
A soft start is not a capacitor. That's called a "hard start". A hard start capacitor stores extra energy that is released into the compressor to give it an extra "kick in the pants". They are intended to help give aging compressors an extra boost to get them running faster if they cannot get going.
A soft start is exactly the opposite. It electronically controls the amount of power going to the compressor to kind of ease it up to speed. The peak power requirement of the compressor is a lot lower.
Our A/C's have an LRA, locked rotor amps, of 62 amps. I've seen some RV air conditioners that have an LRA spec as high as 82 amps. After I installed the Micro-Air EasyStarts on ours the peak current they pull at startup is about 15 amps.
Neither helps after the compressor gets up to speed. If you have a low voltage situation you're still going to have a low voltage situation.
There are people who will claim they are both as effective as the other but if you think about it, the hard start method is a lot harder on the compressor. That translates to a lower life. Not instantly lower but lower. A hard start was designed to give an aging compressor a bit more life. It was already dying anyway so deferring the replacement a bit can be a good thing. Kind of like loading Grandpa up with drugs to get him going a bit longer.
Ray
