Multistage convert upgrade?
Hi,
Trying to decide if I should upgrade to a multistage converter.
I understand it’s benefit of faster charging and not overcharging my batteries when using shore power or a generator. Typically, when we are camping at a site with shore power I use a standard RV/Marine 12 volt battery as back up if needed. I have 2, 6 volt Trojan T105’s I reserve for use when dry camping and shore power is not available. I recharge as needed with solar panels and controller.
I’m not that concerned about charging speed or over charging the 12 volt battery when using shore power and I’m not using shore power when using my 6 volt batteries. Are there other concerns or advantages with my described system that I should consider in making the multistage converter upgrade decision?
I’m assuming the charging occurring while towing the camper is minimal?
Thanks!
