Originally Posted by bclinton
Hello RK, I am getting ready to tackle this with my 2017 GT. (Replace the interconnect relay) Originally, I was going to try and do this without removing the control box but after looking at it that might not be the best way to do this. What is your opinion since you replaced the board. Should I disconnect all power to the RV and chassis battery, take a pic of the wiring and disconnect everything going to the SDC-107 and remove it from the bay. Is the wiring behind the circuit board pretty straight forward once I remove the board? Is the screw in the middle of the board and the one in the top right the 2 attach points for the board? Just a little intimidated by the box
Yes take pictures. I moved my negative chassis battery wires to a Victron BMV-712 shunt. The positive battery chassis cable goes to 500a switch & a Red bus bar.
The short soldered wires make it hard to repair the SDC-107.
I ordered a new SDC-107 black box from
RV Custom Products. They sent it C.O.D. I still have the old SDC-107 in my junk pile.
Did you look at the downloads on the page-link above?
