Heated tank pads usually only work below 40 degrees or so.
If all the other switches are labeled (including water heater switches for propane or electric) then it’s probably for tank pads. If you’ve got a digital meter and can clip on to somewhere to monitor the house 12 volts, you should see a drop in voltage when you turn the switch on, because heaters of any kind usually draw a fair current.
Ken and Terry
