Old 04-01-2017, 06:22 PM   #1
danielabram71's Avatar
Need help with light replacement
I have a 2016 solaire 267bhsk. I have had my 1st light go out. I have never seen a light like this. Does anyone have any idea how to replace and what kinda light bulb to get. Any help is appreciated Click image for larger version
danielabram71 is offline   Reply With Quote
Old 04-01-2017, 06:38 PM   #2
onetonford's Avatar
LED but it looks like you have to replace the whole fixture.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 04-01-2017, 06:53 PM   #3
That's what I was thinking
Old 04-01-2017, 11:12 PM   #4
RangeMaggotBob's Avatar
Looks to me like there's probably a quick-disconnect plug behind that little door on the left. Probably an easy fix/replacement. (Yes- it's an LED)
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2200i generators
RangeMaggotBob is offline   Reply With Quote
Old 04-01-2017, 11:19 PM   #5
Too old to be too smart
SpringerPop's Avatar
You have lots of options if you're good with a small-wattage soldering iron.
Pop
Terry 250RKS, perfect for the two of us and the pups.
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 04-02-2017, 12:00 AM   #6
Tapex's Avatar
Had the same fixture in our Apex go out.
My dealership replaced the whole fixture.Click image for larger version
2016 Coachmen Apex 250RLS Ultra Light
2023 Ram 2500 Big Horn Sport 3.73
Tapex is offline   Reply With Quote
Old 04-02-2017, 01:02 PM   #7
eBay
You can order all kinds of inexpensive LED lights on eBay. Solder them in (remember that polarity matters) and you are good to go. Lots of the new fixtures come non-replaceable bulbs, because everyone knows LEDs last forever. If you want a simple fix, I can highly recommend this fixture. Very bright. Optronics RV LED 12v Fixture Ceiling Camper Trailer Marine Double Dome Light V1 | eBay
mnoland30 is offline   Reply With Quote
Old 04-02-2017, 01:26 PM   #8
I have a similar light and the whole fixture will have to be replaced. Mine is attached with a close hanger type spring. Just snaps out of the ceiling. If your unit is still under warranty FR will replace them. NOW the bad news, mine started going out one by one until 9 lights had to be replaced. FR worked with me on all of the lights even thought some happened after the 12 month warranty! Good luck!!
fkwalter is offline   Reply With Quote
Old 04-02-2017, 03:34 PM   #9
DustyRoads's Avatar
In my 2013 Solaire I had to re-soder the wire going to the switch on the light. Pull the fixture out first and check that.
2017 Forest River Surveyor 251rks
2022 Chevy 3500HD High Country
DustyRoads is offline   Reply With Quote
Old 04-11-2017, 07:39 PM   #10
Update went to the dealer and they gave me the light fixture just have to take them the old one. They warranted it
light, replacement
