Old 05-11-2024, 07:49 PM   #1
snapcap14's Avatar
Need new batteries!
2010 rockwood ss 2604. Time-for new batterie
Present batteries are 2 6volt duracel pro golf cart 20 ah cap 230 120min @75am don’t I installed them in 3/2017 last season they were all but done. Would run furnace and such but not the slide out and had trouble with awning most times. This year winterizing they will not charge.
I’m retired not a lot of disposable income. So can’t go crazy. Definitely can’t afford to redue my system. Even if I could don’t think it’s something I could do myself.
So do i do 12volt do I do 2 6volt again. Golf cart or something else. IS 12 volt golf cart an option
Most of our camping is boondocking . Mostly weekend twice a year 4 days always have 2 Honda 2000 i companion with us
snapcap14 is offline   Reply With Quote
Old 05-11-2024, 08:55 PM   #2
Price on LiFePo4 batteries has come down so much I would give them serious consideration. Many advantages to them, no maintenance, light weight, lots more available AH etc. A small portable charger charger might be needed to top it off.
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equal-i-zer WDH, 1809 lb payload
flyflotrtim is offline   Reply With Quote
Old 05-11-2024, 08:59 PM   #3
Not to mention the LiFePo4 batteries will last 3-5 times the average lifespan od lead acid batteries.
TitanMike is offline   Reply With Quote
Old 05-11-2024, 09:07 PM   #4
Tony Ramirez's Avatar
And you'll get a LOT more usable AHs, so in the morning after a night of furnace use, you will probably not have dead batteries.
Tony Ramirez
2019 Berkshire40D,380HP,1100w Solar, 920AHs LiFePo4
'04 37'Sunvoyager-Sold, '92 30' Pinnacle-Sold
Tony Ramirez is offline   Reply With Quote
Old 05-11-2024, 09:32 PM   #5
snapcap14's Avatar
I always carry a charger. Also. My Honda generator/ inverter what ever it is has a built in charging port that you plug a T shaped plug into with alligator clips on the other end.
What size lifepo4 would I need. I know nothing about them. Even what I read confuses me. I can’t spend $900 on batteries. I’m at $200 range
Old 05-11-2024, 10:33 PM   #6
What size lifepo4 would I need. I know nothing about them. Even what I read confuses me. I canít spend $900 on batteries. Iím at $200 range
The 12-volt port on the Honda generator will require hours and hours to charge batteries. Plug the trailer into the 120-volt outlet and let the converter in the trailer charge the batteries. It will take a lot less time.
There are LiFePo4 batteries, 12-volt 100 aH which are near your price range. I'd opt for those.
Bob
P.S. - We are all on a fixed income. Problem is, mine is fixed too low.
Bob K4TAX is offline   Reply With Quote
Old 05-11-2024, 10:48 PM   #7
snapcap14's Avatar
That was my next question. Getting thru the night this time of year and in October .
Also can you add another battery at a later date. Or do they need to be matched? Like a lead battery.
I may see if I can swing a 150ah instead.
Old 05-11-2024, 10:59 PM   #8
snapcap14's Avatar
Is there any brand to stay away from. Iím seeing some 100ah deep cycle in my price range most seam to have good reviews. Didnít dive to deep into warranty. One i looked at has Bluetooth.. and in my range
Old 05-21-2024, 07:57 PM   #9
Make sure it has a 100 amp BMS. As in current drain is rated for 100 amps.
Blue tooth connectivity is a huge plus, it would eliminate the need for a shunt monitor.
2019 F150 HDPP 4X4 3.5. 2500lb payload.
2018 Rockwood 2506
Half Ton Heavy is offline   Reply With Quote
Old 05-21-2024, 08:55 PM   #10
snapcap14's Avatar
Soory been awhile but was out camping for a week. Thatís what I ordered a lifepo4
batteries
