Old 09-09-2018, 05:07 PM   #1
New Batteries Dead
A friend has a Cedar Creek 5er. He bought 2 new batteries (12v), installed them and used his adapter to plug into a 30 amp outlet. A few weeks later the batteries were dead. He plugged into a 50 amp outlet when he got to the campground and the batteries charged. It seems that the converter isn't on the hot leg from the adapter. How does he fix this? Thanks!
Lexington, SC
2019 FR3 30DS
2001 Jeep Wrangler TJ TOAD
mtnjeeper is offline   Reply With Quote
Old 09-09-2018, 05:16 PM   #2
A 30 amp adapter feeds power to both legs, unless the adapter is defective. He needs to test it with a multimeter or volt meter.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 09-09-2018, 06:48 PM   #3
I'll see him on Tuesday and help him test his adapter. Will report back with the results.
Thanks!
Lexington, SC
2019 FR3 30DS
Old 09-10-2018, 09:29 AM   #4
That seems like it would be a big problem if there were any 220V appliances in his trailer.
BigLou80 is offline   Reply With Quote
Old 09-10-2018, 10:26 AM   #5
can't get 220 from a 30 amp outlet anyway. Single hot leg only. Any 220 appliance (if there were one) would see 0 volts between identical hot legs.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 09-10-2018, 10:42 AM   #6
...far N Georgia!
formerFR's Avatar
Exclamation
Originally Posted by mtnjeeper View Post
,,,used his adapter to plug into a 30 amp outlet. A few weeks later the batteries were dead...
there might be a few more questions to answer before we jump to assumptions:
- was the 30amp outlet 'LIVE' ?
- was the outlet's breaker tripped?
otherwise, is he SURE he actually HAD power while plugged into the 30amp outlet?
The Turners...
'14 Thor Palazzo 33.3 compact diesel 100k+miles since '14... US, Alaska, Canada...
AND a '14 Gulfstream Amerlite
AND a '07 ForestRIver Rockwood : )
formerFR is offline   Reply With Quote
Old 09-10-2018, 11:38 AM   #7
We'll check those things out as well.
Thanks!
Lexington, SC
2019 FR3 30DS
batteries
