Originally Posted by Chuck_S
Many campers have a battery disconnect switch which is designed to prevent the battery power from being siphoned off while the trailer is parked. Several items like the radio memory, LP detector, and maybe a few others are always On and will kill the battery in a couple of weeks.
Not knowing about it makes it unlikely it's Off though but stranger things have happened.
Wrong polarity wiring of a new battery is surprisingly common and the first suspect. A couple of safety fuses and a breaker will trip.
-- Chuck
The Apex is a little trailer, I think. Probably doesn't have a battery disconnect switch.
Look for the fuse/wiring distribution panel. It will have several 10/15/20 amp fuses and a pair of bigger (30/40 amp) fuses. Replace the pair of bigger fuses. If you got even one tiny spark while changing the battery, you will have blown them.
On the bottom of the trailer frame, at the front (either on the hitch part or underneath) you will have one or two "resettable fuses." You will have to lie on your back on the ground to see them. Push the button on the end to reset it. It may or may not have a red plastic jacket like the picture I'm attaching.
