Old 05-17-2024, 08:08 AM   #1
llr
New "hot skin" condition I never thought of before
Yesterday our dog touched the steps and got scarred wouldn't do it again. I found out later a dog on another box also got shocked.
I started checking and found 120v to ground.
Thinking it was my unit I opened the panel and started checking grounds to be sure they were tight. The ground and common buses are very close together and I drew a good arc with matching burn marks on the screw and screwdriver. NOT a loose ground issue. After this I had no more 120v to ground.
On further investigation it turns out each panel in the fairgrounds has 4 30A outlets with the grounds nicely tied together and to the box. But NOT tied back to anything and the boxes are on wooden posts.
Another camper on our box burnt out the water heater do to no water. With no ground it didn't burn completely or trip a breaker and fed power to ground to all units on the panel. When I shorted ground to common I "finished" the element.
This was at the Coshocton county OH fairgrounds in case anyone goes there. I did notify the fair board but am not optimistic.
EDIT: I do have a Progressive EMS on order to detect this in the future
2024 Artic Wolf 3018 Suite 5th Wheel
Prior TT Grand Design 2800BH TT 2021 - sold 4/24
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW Lariat Ultimate
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload - sold 4/24
llr is offline   Reply With Quote
Old 05-17-2024, 08:27 AM   #2
So if I'm understanding correctly, the grounds on the pedestal boxes were floating, and the water heater element failed with a short to ground, but since the grounds were floating they were now live. Definitely not a good situation.
I keep a 3 light tester in one RV outlet at all times, and it has warned me of open grounds at some sites.
2023 Wolf Pup 14CC
2021 Ram 1500 4x4 3.6 V6
dsherman26 is offline   Reply With Quote
Old 05-17-2024, 08:33 AM   #3
wmtire's Avatar
You certainly had an interesting day.
2011 Flagstaff 831 RLBSS
I want to go to Bora-Bora, but Im too Pora-Pora.
Old 05-17-2024, 08:51 AM   #4
llr
Correct, and the water heater failure was in another camper sharing the box.
Old 05-17-2024, 08:55 AM   #5
llr
yes.
And the poor dog, I couldn't feel anything on the steps so made her try again I was not there to see her 1st reaction. I was standing in wet grass with damp shoes so was surprised I couldn't feel it.
Old 05-17-2024, 10:38 AM   #6
In some places, they bond the neutral and ground together at the service point so that a fault current in the ground wire will trip the breaker and eliminate the hazard. NEC come to mind.
2019 Palomino Solaire 147X
2013 Ford F150
TacomaJoe is online now   Reply With Quote
Old 05-17-2024, 10:43 AM   #7
wmtire's Avatar
Maybe you're just a well grounded individual.
Old 05-17-2024, 11:29 AM   #8
llr
I am not sure how these work but mine does not show an open ground, so I won't trust that.
Maybe there is enough leakage (steps, levelers etc) to ground to light the neon bulb.
Old 05-17-2024, 11:32 AM   #9
llr
At least residential that is required at the main service panel. Here I would assume it would be the box on the pole with the transformer. But no ground leaves the pedestal
Old 05-17-2024, 11:33 AM   #10
llr
Or shocked to many times, starting as a toddler that I am finally immune
Old 05-17-2024, 12:03 PM   #11
"EDIT: I do have a Progressive EMS on order to detect this in the future"
Just so you know, an EMS will not detect all types of Hot Skin conditions
Old- 2002 21 Roo
New- 2015 Shamrock 23 IKSS
TV- 2010 Nissan Titan CC
wharfrat48 is offline   Reply With Quote
Old 05-17-2024, 12:55 PM   #12
A fairgrounds implies some sort of municipal entity owning and managing it...likely the county...or worse, the state. With that in mind, the failure to meet code is especially eggregious and highly negligent. After all, it's the county that typically enforces code!
Glad you, your pups, and your rig are OK. This is, as they say, a lawsuit waiting to happen, and rest assured, the County would pay handsomely for this negligence. Perhaps the County needs a new electrical inspector.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Vallecito.
jimmoore13 is offline   Reply With Quote
Old 05-17-2024, 02:09 PM   #13
Grounded?
aircommuter is offline   Reply With Quote
Old 05-17-2024, 03:21 PM   #14
llr
This is a county fairground. I tried to find contact information for the county building department but I don't find it. I did reach out to the fair board and they say they forwarded it to the board president, I am not optimistic about it being properly fixed. Unfortunately it will probably take a lawsuit to get it fixed
Old 05-17-2024, 05:03 PM   #15
Report it as a shock hazard to the power company, they might come out and do a quick test and shut off the power until it is fixed. That would certainly get the attention of the fair grounds maintenance people.
(Previous) Coachmen Mirada Select 37RB
(Previous) Coachmen Freedom Express 246RKS
(Current)2022 Grand Design Reflection150 226RK
2022 F150 Powerboost Hybrid.
DougW is offline   Reply With Quote
Old 05-17-2024, 05:24 PM   #16
This is why every one should have a good EMS like the Hughes Watch Dog. A good EMS would no let any power through with in your situation.
Giboneys is offline   Reply With Quote
Old 05-17-2024, 07:30 PM   #17
Hughes Power Watchdog is bulky and expensive. And I'm very glad I bought one to protect against this type of situation.
2021 Forest River Wildwood 171RBXL
Towed by 2018 Toyota Tundra TRD SR5
reidfo is offline   Reply With Quote
Old 05-17-2024, 07:41 PM   #18
Never hold open with one hand the door to a metal power panel
Especially a Aussie version ........ 440v 3 phase industrial
and try inserting a new fuse with the other hand
Oh boy ........ dat tickles.
proper work boots............ saved me from real big embarrassment.
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 05-18-2024, 12:48 PM   #19
D W
D W's Avatar
Yesterday our dog touched the steps and got scarred wouldn't do it again. I found out later a dog on another box also got shocked......
I started checking and found 120v to ground........
Was just browsing this threat ans saw your comment about reporting the fault. This would be reason enough to avoid this venue like the plague. Nobody's concerned until someone gets electrocuted.
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 05-18-2024, 03:25 PM   #20
llr
This is at a Good Sam rally and more senior people then me say they have been responsive to prior electrical issues so I am am a little more optimistic.
I am not sure how the progressive EMS detects open grounds but my cheap outlet tester does not report it. I wonder id there is enough of a ground though three campers steps and levelers to give a "good" indication when it is not.
I will be a lot more careful in the future, especially with shared pedestals where this is more likely. I am also going start bring long screw anchors and cable to connect to the frame, just in case. And absolutely listen to the dog at the slightest indication.
