New inverter Install problem
My Xantrex Prowatt SW 2000 was acting flaky and finally died. After calling Xantrex, I decided to step up to a Xantrex Freedom Xi for its 4000 watt surge and built in 30 amp auto switch.
I removed the Prowatt, the remote panel, external auto switch and installed the Freedom Xi. I made sure to use black as live, white as neutral and am properly grounded to the chassis. They say you should bond the ground to neutral and I imagine that was done internally through the inverter.
Everything seems to work fine until I plug in to shore power. Even if the inverter and DC power is turned off using the cutoff switch, they both turn on when I plug in. I can't even shut off the inverter or use the cutoff switch to turn off DC! What did I do wrong?
All help appreciated!
Edit: Sorry for double post in wrong section.
2016 Georgetown 364 TSF
2015 FunFinder 242BDS traded for above
2014 Starcraft 1221 Comet traded for above
