Newbie 12v Fuse Block Question
I purchase a 34' 2001 Forest River Georgetown last year and have had quite the good experience with it driving across the country a few times. We had some generator issues which I resolved, but honestly this has been a problem free rig until now. My exterior porch (next to the steps) light has never worked and I started troubleshooting the issue today. Seems that I'm not getting any power to the switch (when I jumper the wire from the switch directly to the battery I get light so the wire and the bulb are good). I followed the wire back to the 12v fuse block under the steps and I found that the lower half of the block has no power when I pull the fuses and check each post. (this is the block the slideout sits on as well which works fine) The main lug going in has power, just nothing at the fuses until I get about 1/2 way up. Does anyone know the model number of this type of panel so I don't have to cut the connector and wire to a new subpanel? I've attached a pic of the block if anyone has any ideas that would be great.
