Ac is AC and DC is DC. All 110ac outlets need you to connect your trailer to an external AC source (unless you rig up an inverter to a dedicated outlet). DC, I.e., battery power, is the source for control power on the gas heater and refrigerator when gas powered as well as the water pump and tank sensors all the time. Also your lighting. I added a 12VDC plug and monitor panel in my trailer. You can buy an appropriate sized for your coffeemaker inverter and use that. However, it’s much simple to use your gas burners to heat the water and use a drip filter holder or a French press to make coffee when an AC power source is unavailable.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
