06-07-2022, 10:38 AM
#21
Power Requirements
After reading and reading many posts pertaining to electrical issues, both 12VDC and 120VAC, 30A and 50A services, it has come painfully clear........
(a) If one doesn't know what they are doing, they shouldn't be doing it.
(b) If one THINKS they know what they are doing........they should seek the service of a knowledgeable and experienced person.
RVs, TTs, MHs, all have relatively complex electrical systems. The casual DIYer likely shouldn't be tampering with these systems. My point, if one does not own or know how to use a VOM, then the electrical systems should be taboo and off-limits.
06-07-2022, 12:44 PM
#22
I'm Lost
X2
Geoff, Francesca and Lucy the Golden holy terror (I mean retriever, BD Nov. 2018)
2023 F150 Screw, 3.5L, HDPP, LT tyres.
2013 Rockwood Signature 8310SS
2023 F150 Lariat 502A (After all rebates, price protection and dealer discounts, I saved $12,600Cdn. (Cavalcade Ford). If pays to shop dealers! (April 2023)
06-07-2022, 01:00 PM
#23
I'm Lost
Originally Posted by nvs4602
A small problem....
See the black fin thingies.... well they're called heat-sinks, designed to radiate heat into the surrounding air which takes the heat away by convection currents. The heat removal process requires free air flow which you cannot get in a small closed container.
Component failure at the minimum, possible fire before the fuse fails at worst.
Minimum to fix this would be to move the heat-sinks to the outside of the case, then hardwire to voltage regulators direct to the PCB.
These cheap regulators waste a pile of energy to heat.
Take-away; Buy a good quality variable regulator designed for auto/harsh environs and sleep at night with the insurance the RV won't burn down around you.
06-07-2022, 01:05 PM
#24
I'm Lost
Originally Posted by Midwest Ed
One could always add an inline fuse holder and fuse properly rated for the existing wire gauge or whatever is the "weakest link" (i.e. wire gauge or inverter rating).
Ed, you're quite correct.
The only issue is the second time they blow the fuse someone will assuredly put a larger fuse in it's place. Human nature. That's why we no longer has fuse panels in newer homes.
