Old 10-23-2018, 12:33 PM   #1
No 12 volt pwr
I have a 2014 Flagstaff 8528 IWKS was recently dry camping using a Champion 75331 gen invertor. After disconnecting the generator no 12 v power inside the fiver. Can operate slides on 12v but no lights water pump or anything else 12v? Had battery tested checked good
btown cmpr is offline   Reply With Quote
Old 10-23-2018, 01:01 PM   #2
Look for your battery disconnect switch.
DYNAMAX 2016 FORCE HD
houstonstroker is offline   Reply With Quote
Old 10-23-2018, 01:10 PM   #3
Your slide could be connected directly to the battery that's why it works, all the other 12v power will go through a circuit breaker. Follow the positive cable from the battery to under the trailer frame and look for a circuit breaker as shown above. It should have a reset button.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
boondocking is offline   Reply With Quote
12 volt
