Originally Posted by ysidive
Have trailerplugged in but have no power. checked power source ok. checked breakers buthave no power. If the converter went bad will this cause me to have no 120 in the rv ?
OK... what is your power source?
What breakers did you check? (and how?)
Are you using any kind of adapter?
Start at the source with a meter and test voltage with nothing plugged into it.
If OK, then plug your R/V cord into the source but NOT into your R/V.
Test for voltage at the plug end that goes to your R/V.
If OK, then connect to the R/V and go to your power distribution (breaker) box and check for voltage at the incoming side of the main breaker.
If OK, make sure the main breaker is ON and then start testing voltage at each of the branch circuits.
