Originally Posted by Flybob
Walmart has them. You might also check the campground some have them to loan out.
Im betting that next time a 50 amp is available the OP will opt for the additional expense of plugging into the 50 amp service.
The additional cost was cheap compared to the aggravation he suffered.
He tried the "cheap charlie" solution with that adapter and it bit him in the butt.
There is an upside for the OP though. He has now learned how that Y adapter is wired so if he tries using it in the future he knows what to check to insure he has power to both sides of his load center.
We happen to have both adapters to 30 Amp, one with the 20 amp pigtail and one without but they are ONLY for use when no 50 amp is available.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
