Old 05-08-2021, 08:27 AM   #1
No 12v POWER in Roo 233S
Relatively newbie here and need help from my fellow camper friends with more expertise.
I am at my seasonal campsite with my 2018 Rockwood Roo 233s and arrived last night and no lights and fridge power while plugged into shore power.
Verified shore power connection is good and battery disconnect is not activated. All fuses look good and reset main breaker and converter breaker just in case. Outlets and TV work, just the 12v system is not being converted down from the 120v to operate fridge, heat, and lights?
Perplexed on this one and hoping I can get support from my fellow camping friends here.
RockwoodRoo233s is offline   Reply With Quote
Old 05-08-2021, 08:57 AM   #2
SeaDog's Avatar
welcome to the forum its a great place to get your questions answered It sounds like the converter has gone south and your batteries are dead. First take a multi meter and measure the 12V power from the converter should be something >13V disconnect your batteries and measure the voltage on each to see where they are at. If the converter has failed you can hookup a stand alone charger to your batteries to provide charging and power to your 12V equipment. Let the forum know what you find.
Retired Navy
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
Old 05-08-2021, 09:06 AM   #3
fonzie's Avatar
Is your battery hook up properly. If not, then change connections and check reverse polarity fuses in the distribution panel.
Fonzie
Old 05-08-2021, 09:22 AM   #4
The battery is showing 2/3 good on the panel and checked reset button under a frame.
Old 05-08-2021, 09:24 AM   #5
rsdata's Avatar
YES... did you change out or re-hook the battery correctly?
try dis-connecting the battery completely
and while there follow the battery cable to a 4x4 electric box with a small fuse with a small black push button and reset it AFTER disconnecting the battery...
hooked to shore power even without a battery you should get 12V lights inside
2014 Shamrock 183
Old 05-08-2021, 09:25 AM   #6
rsdata's Avatar
2/3 good is NOT good... disconnect battery
do you have a volt meter? what is the voltage of the battery when disconnected?
if no meter pick up a $10 one from a hardware store...
2014 Shamrock 183
Old 05-08-2021, 09:26 AM   #7
Hi Seadog, thank you for your response.
The battery is showing 2/3 on the panel and also checked reset switch under the A Frame.
Old 05-08-2021, 09:32 AM   #8
Mr. Dan's Avatar
Check the breaker for your converter. If you’re plugged into shore power, the panel monitor for battery should be showing all 4 lights - indicating the converter is charging the battery regardless of the battery’s charge level.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 42; Booked = 36
Old 05-08-2021, 09:44 AM   #9
Ok, disconnected battery and reset switch and still no lights inside ....
Old 05-08-2021, 09:45 AM   #10
Thank you, i reset breaker and still no lights...
Old 05-08-2021, 09:50 AM   #11
Thank you for your response.
Battery disconnected as suggested
Old 05-08-2021, 10:06 AM   #12
Reset breaker and no change... no 12v lights
Old 05-08-2021, 11:51 AM   #13
Thank you SeaDog for your insight.
I measured the batteries and reading 5.3 and 7.2 volts on each. When measuring the converter, not getting any measurement reading from the converter. Im at a loss here...
Old 05-08-2021, 12:16 PM   #14
rsdata's Avatar
First and foremost the batteries are shot... there is no recovering a battery that is that low.
The converter may also be shot... but let's not jump to that yet.
Can you buy or borrow just one battery to put into the trailer?
Make sure it is hooked up right. One battery should power the lights.
I would disconnect from shore power when doing this.
2014 Shamrock 183
Old 05-08-2021, 12:18 PM   #15
bikendan's Avatar
Clearly your battery are dead and probably not recoverable. That's why you don't use the battery idiot lights while plugged into shore power.
And if you're plugged into shore power and you measured the converter correctly, then the converter is bad.
Old 05-08-2021, 12:42 PM   #16
My guess is the converter went bad, then the batteries ran down, and now you have nothing left - bad converter and dead batteries.
NavyLCDR is offline   Reply With Quote
Old 05-08-2021, 12:55 PM   #17
Jumper Cables!
For this test, the OP could just use jumper cables from his tow vehicle with the trailer batteries disconnected.
Larry
Larry-NC is offline   Reply With Quote
Old 05-08-2021, 02:00 PM   #18
Tom48's Avatar
Did I miss it. Reverse polarity fuses need to both be good.
If the idiot lights showed two thirds, the converter/charger might be trying
Tom48
In Sunny So Cal /w
Now in 2005 Holiday Rambler Ambassador DP and The Hot Air Balloon RESTLESS
NO MORE Tricked out
2017 Sandstorm 250 T.H.
Tom48 is offline   Reply With Quote
Old 05-08-2021, 02:04 PM   #19
12v power
I had a similar problem turned out to be a dirty(crappy) ground from battery to frame. Wire brush and scrape some paint from frame. Re spot paint when all reconnected
pdqparalegal1 is offline   Reply With Quote
Old 05-08-2021, 02:13 PM   #20
RiderBloke
RiderBloke's Avatar
I think the replies have it right; however just another check - have you checked the breaker that powers the converter? It may have been turned off for some reason OR have blown when the batteries being so low were connected. Good luck with fixing this problem.
Retired Intentional Interim Minister
Member of the BMW MOA
Saginaw Valley BMW Riders
RiderBloke is offline   Reply With Quote
233, 233s, power, roo
