Old 07-20-2020, 08:00 AM   #1
2009 F450 2015 Cardinal
No 12V power this morning
Woke up this morning with no 12 volt power in my 5th wheel. We are boondocking and the critical piece is it has the fridge/freezer off. Batteries are tested and fine. Battery switch is ON. Call is in to Cardinal tech help. Thanks
It is a 2015 Cardinal 3875FB
AntonJ is offline   Reply With Quote
Old 07-20-2020, 08:18 AM   #2
Flybob's Avatar
Did you check the resettable breaker under the frame near the hitch?
Is this the original Battery?
How are you testing the battery?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-20-2020, 08:26 AM   #3
Daycruiser's Avatar
Volt meter working from the battery toward the distribution panel until you find the open circuit. Could be a resettable fuse, hard fuse, loose connection, bad battery switch, bad ground, any number of fun things to check. What is the actual battery voltage? If you fire up a genny do you get 12 volts back from the converter?
45 Years RVing and no end in sight.
2018 Ram 3500 SB Limited, CC, 6.7/Aisin, 4X4, SRW. Comfort Ride Energy Absorbing Hitch.
2020 Cedar Creek Hathaway 34IK, Reese 19K Sidewinder PB.
Daycruiser is offline   Reply With Quote
Old 07-20-2020, 08:33 AM   #4
Being a fifth wheel the resetable breaker will likely be in or near the battery compartment, not near the hitch. It will have a button push.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is online now   Reply With Quote
Old 07-20-2020, 08:44 AM   #5
As mentioned, start at the battery, testing with a voltmeter and work your way towards the power distribution box.
You have to start with the basics.
Days Camped: '17=30 '18=51 '19=58 '20=88
Old 07-20-2020, 08:52 AM   #6
I tested the batteries with a volt meter. Also, my solar controller agrees they are at 12.65 I do have 12volt power with the generator running. I don't know what the resettable breaker looks like. Anybody have a picture?
Old 07-20-2020, 08:53 AM   #7
fonzie's Avatar
Here it is....
https://www.forestriverforums.com/fo...et-154141.html
Fonzie
Nights Camped:2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42) 2019(28)
Old 07-20-2020, 08:55 AM   #8
As a confounding or maybe illuminating factor, I had let the propane tank run out. Could that have tripped something with the refrigerator and water heater continuing to try to reignite the propane?
Old 07-20-2020, 09:25 AM   #9
I cannot find the resettable breaker so far. Also, I wanted to insert an image to show you all what the gizmo in front of my battery bank looks like, but I don't know how to do that. The insert an image icon requires a URL and I cannot do a simple copy/paste. Feeling particularly dumb this morning...
Old 07-20-2020, 09:47 AM   #10
Head Rambler
if you're on a PC can click (or touch) the 'Go Advanced' button at the bottom of the Quick Reply window and you can add pictures from there by searching your local device.
Gotta go campin!
Old 07-20-2020, 09:52 AM   #11
Read here to post photo. Post 7.
http://www.forestriverforums.com/for...html#post49621
Andersen hitch
Old 07-20-2020, 10:11 AM   #12
I think this is the 200amp fuse / it is intact
I'll see if the image loaded.
Old 07-20-2020, 10:28 AM   #13
Head Rambler
Did you test that fuse with a meter?
Gotta go campin!
Old 07-20-2020, 10:33 AM   #14
Yes that is a fuse, not a circuit breaker. Test it as recommended above, and keep testing a you go downstream until you find the break. Your circuit breaker is apt to be covered by the red rubber shield as pictured above. Peel that back to test the power or access the reset button the side.
Andersen hitch
Old 07-20-2020, 11:27 AM   #15
Issue resolved
OK, Thanks for all your help. And thanks to Don McWilliams the Cardinal rep at Forest River. In the close up pic, the knife breaker on the left was the culprit. The one on the right controls the hydraulics. It was not fully tripped, but I thought I had tripped and reset it in an earlier attempt to resolve the issue. But, when I did it a second time it reset the system and all is well that ends well. The crazy thing is when it is fully tripped it is really easy to see, but it was not visibly tripped yet responded to a reset.
ID:	234330   Click image for larger version
ID:	234331   Click image for larger version
Old 07-20-2020, 11:46 AM   #16
Head Rambler
Thanks for letting us know what you found. I'm glad it was as easy as resetting a breaker, even if it was a bit of a challenge to find.
Gotta go campin!
Old 07-20-2020, 12:07 PM   #17
Also, thanks to the folks that held my hand through the picture posting part too.
BTW: I don't know, but I do suspect the running the system out of propane had something to do with the breaker tripping. After spending a decade (the '80's) in Law Enforcement, I am deeply suspicious of coincidences.
Maybe the frig or the hot water heater continuously trying to reignite?
Old 07-20-2020, 12:09 PM   #18
Things like that are always easier to find the next time
This would be a nice thing to add you a new RV PDI/Checklist.
Location of ALL circuit breakers and hidden fuses. ALL OF THEM.
"A wise man can change his mind. A fool never will."
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 07-20-2020, 12:12 PM   #19
I was definitely the tree for a while this morning!
Old 07-20-2020, 12:22 PM   #20
There is a thermal fuse located in the refrigerator someplace near the propane ignitor. Mine was attached to a red wire that had some heat shrink on it. I had the same problem and was able to replace it and fixed the problem. Fuse type SF152E. Ordered on Amazon for $7.41 for a package off 10.
Rich McF is offline   Reply With Quote
power
