Old 02-16-2017, 08:34 PM   #1
Crop Duster's Avatar
No Battery Power.... Please Help
So we were suppose to head for a trip to Canada tonight and pulled the camper into the street to finish packing it. Well come to find out I don't have any battery power in the camper. When plugged into shore power everything works (fridge, outlets, lights, microwave, etc...). I have a Trimetric 2030 hooked to the batteries and they are at a full charge.
I have power to the front and rear of the breaker that is connected to the frame on the front. I also have full power to both wires on the back of the factory battery disconnect switch. I'm at a loss.... Four days ago I had it in the street doing some maintenance and everything worked fine. Where else should I be looking?
Hyper Lite 27HFS
Dodge Ram 3500 Long Bed Mega
@adventurerig
Crop Duster is offline   Reply With Quote
Old 02-16-2017, 08:40 PM   #2
I assume the 12 volt fuses have been checked?
Kimber45 is offline   Reply With Quote
Old 02-16-2017, 08:59 PM   #3
Yeah all the fuses have been checked including the main. If a fuse was blown would that particular item still work on shore power?
Hyper Lite 27HFS
@adventurerig
Old 02-16-2017, 09:08 PM   #4
bikendan's Avatar
Check the resettable fuse along the A-frame.
Press the tiny black reset button.
Old 02-16-2017, 09:26 PM   #5
I've checked that breaker on the frame and the black button is pushed in. I also have 12v power on the top side which is the cable running into the camper.
Hyper Lite 27HFS
@adventurerig
Old 02-16-2017, 09:29 PM   #6
Left Coast
Check at the converter next
Old 02-16-2017, 09:32 PM   #7
Seems like I don't have power at the converter when on battery power. The red wire is hardly reading anything.
Hyper Lite 27HFS
@adventurerig
Old 02-16-2017, 09:37 PM   #8
Left Coast
Pinched wire....
Old 02-16-2017, 09:39 PM   #9
Left Coast
For a quick fix, string a new one till you have more time.....
Old 02-16-2017, 09:45 PM   #10
Okay now to add to the confusion. This entire time my Trimetric has been reading 12.9V even though I'm plugged into shore power. I don't know why it's been reading low but I didn't pay too much attention to it (I just installed it 2 days ago and I'm getting used to having it and what the numbers can mean). Well I just went out to the camper to check more wires and noticed when I walked into the camper the Trimetric was reading 13.6V (which is what it normally reads when it's charging). So I thought what the hell, I'll just unplug from the shore power and see what happens. Well everything works now. I haven't done a dang thing. What is going on?
Hyper Lite 27HFS
@adventurerig
Old 02-16-2017, 09:49 PM   #11
Left Coast
That checked the wire as being good, so I'd say the converter might have a bad or loose connection
Old 02-16-2017, 09:52 PM   #12
Left Coast
This trailer has a Progressive hard wired unit, but the numbers are the same......edited last post
Old 02-17-2017, 01:55 PM   #13
Dwilli's Avatar
My experience on battery power
Just throwing my 2 cents in but I had the same issue and had to call a tech in. Was on a fiver and over a period of about 6 months, had no battery power. Long story short ended up a factory issue where all the connections from stem to stern on the 12v side needed tightening. Even behind the fuse panel. There as also a breaker under the exterior back and the contacts were loose there also. $500 later in labour, everything worked great. Hope this isn't your problem but check the contact connections.
Dwilli
Dwilli is offline   Reply With Quote
Old 02-17-2017, 02:52 PM   #14
donNjudy's Avatar
Could someone watch a light when nothing is working and could you wiggle wires till the light burns? Then wiggle till the light doesn't burn make the problem come and go. Narrow it down and find what might be a loose connection.
donNjudy is offline   Reply With Quote
Old 02-17-2017, 05:23 PM   #15
Self reseting breaker. Mine is near the battery switch.
Pursell is offline   Reply With Quote
Old 02-17-2017, 06:10 PM   #16
Evereddie's Avatar
Battery disconnect switch? Do you have one?
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
Evereddie is offline   Reply With Quote
Old 02-17-2017, 06:55 PM   #17
Reading comprehension 101
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre - Tow Package
Boon Docking 99% of the time.
boondocking is online now   Reply With Quote
Old 02-17-2017, 07:47 PM   #18
Left Coast
Yep
Old 02-17-2017, 07:52 PM   #19
Mr. Dan's Avatar
See original post: "I also have full power to both wires on the back of the factory battery disconnect switch."
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 28; Booked = 50
Old 02-17-2017, 10:11 PM   #20
Well it seems to be working for now. We're on the road with it but before we left I was able to find some loose nuts on the wiring for the breakers on the tongue of the trailer directly after the batteries. I don't think that was the problem since I had power to the battery disconnect switch which is inside the trailer. But I'm keeping my fingers crossed that maybe it fixed itself.
Hyper Lite 27HFS
@adventurerig
battery, power
