Old 04-01-2024, 02:22 PM   #1
No interior lights off shore power
Checked fuses. Meter shows no power from battery to electric panel.
Do not see battery disconnect switch anywhere on unit or in owner's manual. 2015 Prime Time Crusader 29RS. everything works great on shore power. Any ideas appreciated.
OutForFun24 is offline   Reply With Quote
Old 04-01-2024, 02:56 PM   #2
wmtire's Avatar
See this thread below in case your 12 volt DC circuit breaker needs resetting.
https://www.forestriverforums.com/fo...et-154141.html
2011 Flagstaff 831 RLBSS
I want to go to Bora-Bora, but Iím too Pora-Pora.
Old 04-01-2024, 05:54 PM   #3
Dead battery?
JB_Canuck is offline   Reply With Quote
Old 04-01-2024, 06:18 PM   #4
When you're off shore power, those overhead lights are powered by the battery. So the first place to check is your battery and if you've got a battery cutoff switch. If you're battery is ok, then do as above and check your fuses.
Welcome to the forum!
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
interior lights, light, power, shore power
