Old 06-29-2024, 02:04 PM   #1
No lights or control panels
I have a 2020 silverback. The converter breaker popped and I reset. I have no lights or control panels. All plugs workand microwave. I checked converter fuses they are good. It appears all 12 voltsystems are out, what am I missing.
Louis g is offline   Reply With Quote
Old 06-29-2024, 02:17 PM   #2
PhilFromMaine's Avatar
A converter breaker flipping most likely indicates something wrong with the converter. If the converter isn't working, then the battery isn't getting charged and the battery will fail if not being charged by something else.
Converter failure will not necessarily blow the converter 12v fuses. You can check out the converter easily with a multimeter-120 in and 12 plus necessarily amperage out. Presumably your battery is dead.
2018 Coachmen Freedom Express Liberty Edition 231RBDSLE
PhilFromMaine is offline   Reply With Quote
Old 06-29-2024, 02:31 PM   #3
Flybob's Avatar
Turn the breaker off and back on. Reset requires it be off ( not tripped) to reset.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-29-2024, 08:11 PM   #4
bikendan's Avatar
Moved thread from the Appliances and Electronics sub-forum to the Electrical and Charging Systems sub-forum since the OP's questions are specific to that sub-forum.
control panel, light, panel
